Hello all, I’ve had nothing but issues using both the Plex official Docker container with Docker for Windows. I feel like most of it could be chalked up to pure instability of the Docker service for Windows itself, but if there’s anyone out there with a successful working build of Plex in this fashion, I’d love to pick your brain.
The issues I’ve had -
Inability to restart/kill/stop the container - leading to a full restart of the Docker service.
Posters never fully fetching for all TV Shows in the library (sometimes occurs on Movies) Metadata fetching seems to just stop working after some time.
Random failures of the Plex service, where the “There was an unexpected error loading this library” error is present and only destroying the container and restarting the Docker service “fixes” the problem
The Docker host is a Windows 10 on the current 1803 build, Intel i7 5960X with 32gb of DDR4. A few 10TB NAS drives directly attached (no network mounted shares). I’d be more than happy to provide logs and other diagnostic information, but I’m mainly curious to see if anyone has gotten these containers to work at all or if I should just keep it in its current VM. I’m looking to migrate all of my HTPC services over to Docker containers entirely.
Generally, playing from the container seems to work as expected, no issues with claiming or reaching the web interface, it just seems to be issues with the agents or the container itself. I’ve tried removing the image and container and rebuilding, running the container on the host-only network, all to no avail. Below is the Docker Run command I’m using.
docker run -d --name plex \
-p 32400:32400/tcp -p 32400:32400/udp \
-p 3005:3005/tcp -p 8324:8324/tcp \
-p 32469:32469/tcp -p 32469:32469/udp \
-p 1900:1900/udp -p 32410:32410/udp \
-p 32412:32412/udp -p 32413:32413/udp \
-p 32414:32414/udp -p 5353:5353/udp \
-p 33400:33400 -p 33443:33443 \
-e TZ="America/Chicago" -e ADVERTISE_IP="http://172.16.5.1:32400" -e PLEX_CLAIM=*snip* \
-h dockerplex -v C:\Docker\Plex\config:/config -v C:\Docker\Plex\transcode:/transcode \
-v D:\:/data --restart unless-stopped plexinc/pms-docker;
Thanks!
