In the web client, you can do EVERYTHING except that.
Security risk? You can delete a collection, change port, etc.. but no shut down or restart?
All web clients managing a server in those kind of environment have those functions (CouchPotato, SickBeard, MB3, SABNZDB etc...) I was just surprised when I first start using Plex that this option wasn't there in the first place...
Even if "it's not supposed to be needed", for me, it's common sense to have it... (it's not because it's there that you have to use it and it's not just to fix crash or other issues, it could simply be for other maintenance tasks or tests)
Please do say it out loud, and repeat that about 100 times, cuz nobody except you can hear it :P
In order to make a vote count, you'll have to like the first post in this thread
A +1 simply means, that you wasted the time of a lot of people, and causing the needed disk space for hosting this site increase, not to mention backup :rolleyes:
Please read the FAQ pinned on top of this fora about how to vote.
Wouldn’t it be better to have some kind of watchdog and do this automatically when something goes wrong? Usually it is needed to clean up some stalled transcoding job, but if the webserver hangs a remote button isn’t that usefull.
What I do, is restarting the Plex mediaserver every night at 4:00 AM anyway. This is to make sure that when my server hangs, I can still watch movies the next day, even when on holliday.
Just wondering, how do you do that? With a script that kills the PMS process and then restarting it? Or do you have a cleaner way of doing it? Because I was planning on implementing this too, but I don't know if straight-forward killing the PMS process can damage stuff..
Killing a process shouldn't damage anything, a kill command is similar to quitting an application. However killing doesn't always work, basically if a process is unresponsive, then you would use a kill -9 which is similar to force quitting or ending a task, which in most cases will not cause any problems but has the potential.
I have a small script, that basically kills the process, waits 30 seconds, checks if the process is still visible in a "top", if so, it does a "kill -9". After that, I can start the process again.
I have two reasons for doing that: first is that I want to make sure I can use it the next day, second I can guarantee no changes during my backup. In theory it could leave the database in an inconsistent state, but these things can be fixed easily from the webinterface. It is quite effective when done at the right time (around 4AM), so nobody is using it.
Yeah, that code isn't very helpfull to me as I'm on Windows haha! :D
But thank you for outlining the steps! Now I know what you meant with the 30 seconds, wasn't clear to me before.
I'll just recreate this stuff for windows for my own benefit, the steps you take are really interchangeable between any OS, it's just the tooling that's different. So thanks!
If anyone is interested just let me know here, I'll post my (windows) batch script over here...
I noticed something kills the script as well. In the 'service plexserver stop' some returncode causes the script to abort. It only happens when Plex is running, and only in the "crontab" context, so it is a nasty one to tackle.
I noticed this two days before my hollidays, so i replaced with two seprate cronjobs, one to stop and one to start, but I will investigate further in January...
I really don't understand why this isn't implemented yet...
I know usually it's not ok to presume it's an easy fix or "a switch to flip" but in this case, very close IMO.
Anyway, in meantime, if I need to restart, I RDP in the server close and reopen PMS from task bar (not that I need to do it often but it's just common sense to be able to do this from Plex/Web)
