Web-connect
Is there a way to make a additional port or something to access certain settings on plexconnect using a webpage like how a router can be configured? I see that there is a error response page that just displays your plexconnect host ip and the ip trying to connect that is a non atv device. Example 192.168.1.101:32500
I guess what im hoping is that there could be a way to upload a new trailers.pem if need be. Edit and save your settings.cfg or upload a new one. Do a git pull from this router based scheme or really anything we want to do that can then be edited and changed on your plexconnect host
And then to finish it off give it a login to keep unwanted users from changing your settings.
Trying to name it webconnect sorry guys. Stupid auto correct. Forum leads if you could correct topic title it would be appreciated.
It is a lot of dev effort to not really give any real extra functionality, ie currently better to use that effort on other features.
Also, once Plexify open sources it’s code and it can be verified and possibly recommended as a supported way of installing PlexConnect, it would appear to be a better idea to add that kind of functionally into helper apps like that (especially as Win and Nix versions appear to be on the way).
The not serving client error is intentional - thought maybe it might be better to server up a web page that says something else.
