Webservice integration
Would be fantastic if Plex could expose a series of web services, which would allow data to be retrieved and actions to be called. At the moment I am a .NET/C# developer so am unable to quickly program in Python, but would love to integrate with the solution.
Check out http://127.0.0.1:32400/ and search the forums for docs.
Communication is simple with XML over HTTP or JSON over HTTP. The .NET framework has excellent facilities for XML out of the box, so I wrote a ‘Plex’ class that serves as a dynamic wrapper around the data. Here’s an usage example:
using (var wc = new WebClient()) {
wc.Encoding = Encoding.UTF8;
foreach (dynamic section in new Plex(wc.DownloadString(“http://127.0.0.1:32400/library/sections”))) {
Console.WriteLine(section.Title);
And the class that serves as dynamic wrapper:
using System;
using System.Collections;
using System.Dynamic;
using System.Linq;
using System.Xml.Linq;
namespace PlexLibraryToHtml {
/// Represents dynamic XML for Plex.
public sealed class Plex : DynamicObject, IEnumerable {
/// Contains the attribute.
private readonly XAttribute _Attribute;
	/// <summary>
	/// Contains the element.
	/// </summary>
	private readonly XElement _Element;
	#region Constructor
	/// <summary>
	/// Initialize a new instance of the Plex class.
	/// </summary>
	/// <param name="Document">The document.</param>
	public Plex(string Document) {
		// Set the element.
		_Element = XElement.Parse(Document);
	/// <summary>
	/// </summary>
	/// <param name="Attribute">The attribute.</param>
	public Plex(XAttribute Attribute) {
		// Set the attribute.
		_Attribute = Attribute;
	/// <summary>
	/// </summary>
	/// <param name="Element">The element.</param>
	public Plex(XElement Element) {
		// Set the element.
		_Element = Element;
	#endregion
	#region DynamicObject
	/// <summary>
	/// Provides implementation for type conversion operations.
	/// </summary>
	/// <param name="Binder">Provides information about the conversion operation.</param>
	/// <param name="Result">The result of the type conversion operation.</param>
	public override bool TryConvert(ConvertBinder Binder, out object Result) {
		// Attempt the following code.
		try {
			// Change the type of the value to the binder type.
			Result = Convert.ChangeType(ToString(), Binder.ReturnType);
			// Return true.
			return true;
		} catch {
			// Initialize the default.
			Result = Activator.CreateInstance(Binder.ReturnType);
			// Return true.
			return true;
	/// <summary>
	/// Provides the implementation for operations that get member values.
	/// </summary>
	/// <param name="Binder">Provides information about the object that called the dynamic operation.</param>
	/// <param name="Result">The result of the get operation.</param>
	public override bool TryGetMember(GetMemberBinder Binder, out object Result) {
		// Check if the element is invalid.
		if (_Element == null) {
			// Set the result.
			Result = null;
			// Return true.
			return true;
		} else {
			// Retrieve the attribute.
			var Attribute = _Element.Attributes().FirstOrDefault(x => string.Equals(x.Name.LocalName, Binder.Name, StringComparison.InvariantCultureIgnoreCase));
			// Check if the attribute is invalid.
			if (Attribute == null) {
				// Set the result.
				Result = null;
				// Return true.
				return true;
			} else {
				// Set the result.
				Result = new Plex(Attribute);
				// Return true.
				return true;
	#endregion
	#region Object
	/// <summary>
	/// Returns a string that represents the current object.
	/// </summary>
	public override string ToString() {
		// Return the attribute or element value.
		return _Attribute != null ? _Attribute.Value : _Element.Value;
	#endregion
	#region IEnumerable
	/// <summary>
	/// Returns an enumerator that iterates through the collection.
	/// </summary>
	public IEnumerator GetEnumerator() {
		// Return the enumerator.
		return _Element.Elements().Select(x => new Plex(x)).GetEnumerator();
	#endregion
Fantastic, thanks guys!!!!
