WebTools-NG
Had a drive fail on my headless linux server that hosts only PMS and wanted to get a list of what was missing.
Have been migrating to new drives slowly, so no recent relevant backups or anything adjacent to recover from.
Went to use WebTools-NG “Find Media” to find what was missing. Since the drive died and can’t be mounted, I had to just link to the empty mountpoint in “library mapping” for that drive. The others are still fine.
“Find media” will process 700 of 746 files and then hang. I even tried letting it sit for long while, hours. It never finishes or lists what’s missing.
Is it that this tool is not built to provide a solution, to report the missing media and list said media in this particular situation (dead drive that can’t be mapped in global settings properly) or am I missing some kind of alternative or special settings, info, or setup?
Try and export the different libraries, and you should be able to get the file path
I see! I thought Find Media was the only way. The way it read I thought the export was for exporting the literal media and posters etc only. Then when I figured out the spreadsheet output what I got out was… daunting.
I realized later the default settings for output werent in global settings and wasn’t using a csv standard delimiter (it was set to pipes |) and so everything was just in one cell on each row. I thought maybe I needed some kind of special viewer or maybe it was just for reimport only. Then I found the export specific settings, switched to commas and the output was interpreted by excel and I found the pathways!
Thank you!
Hello everyone. Thank you for WebTools-NG. Is there a way to extract the “By Added Date” data (see screenshot of Plex server)?
In my extract from WebTools-NG, Column A is labeled as “Added” but these dates aren’t the dates I added them to Plex.
I would like to keep track of the dates I added movies to my collection.
Very good tool!
I need to find the date of the last playback of a content by any user in my library, can I?
When I use ExportTools, it only shows the date I watched it.
Can I change charset? “Mistério-Ficção” is appearing.
Sadly not, since that would req. the tool to logon as all the users one-by-one, and not good for this
The charset should be universal, as in utf-8
Can WebTools-NG be used to export the star ratings for individual audio tracks? I just downloaded the tool and it works great, but I am baffled that track ratings don’t seem to be included in the exported metadata. I did:
ExportTools > Audio > Audio Track > Music Library > All Export Level
edit: I guess not according to this page. But there has got to be some way to modify the program to make this work, right? Any suggestions for a different tool? :-/
Development has been on hold for a while, but you are welcome to fork the github repo and make the needed changes
As an alternative, maybe this one: Exporter Guide · Tautulli/Tautulli Wiki · GitHub
Thank you sir, I appreciate the guidance! Looks promising.
edit: Tautulli works great! No disrespect to WebTools-NG, but this is more in line with what I was looking for. Thanks again. I was able to backup my playlists too even though my current Plex database is corrupt and I cannot view the playslists through the web.
I agree. It makes no sense at all that we have to create a shortcut for this.
Is it possible to point the tool to a backup copy of an old plex media server folder? I recently lost a hard drive but was able to save a copy of my plex media server folder. I was hoping to use the tool to get a list of my old plex media content
No, it needs a running PMS, sorry
No problem thank you for the info
@claudia.thompson2
Maybe this one: Where to find list of deleted/cleaned up movies and tv shows
Thank you! I’ll give this a shot!!! You da bomb
This worked!!! Thank you so much!!!
Hi @dane22 thank you for the tool :slight_smile:
I only need it to find missing episodes, but unfortunately it gets stuck at the 13th series, as you can see in the photo:
I set the log file to “silly” to get as much information as possible, but it only said:
[2026-02-15 18:25:12.977] [info] [ethelper.js] (addRowToTmp) - Level “Find Missing Episodes” selected, so we must contact tvdb
[2026-02-15 18:25:12.980] [info] [ethelper.js] (addRowToTmp) - tvdb aired selected for the show named node
[2026-02-15 18:25:12.982] [info] [tvdb.js] (getTVDBShowDVD) - Getting tvdb official info for 350667 with a title of: A Million Little Things
[2026-02-15 18:25:13.194] [verbose] [ethelper.js] (getShowOrdering) Calling url: https://192.168.111.1:32400/library/metadata/112830?includeGuids=1&includeChildren=1&includePreferences=1&checkFiles=0&includeRelated=0&includeExtras=0&includeBandwidths=0&includeChapters=0&excludeElements=Actor,Collection,Country,Director,Genre,Label,Mood,Producer,Similar,Writer,Role&excludeFields=summary,tagline
[2026-02-15 18:25:13.214] [info] [ethelper.js] (addRowToTmp) - Level “Find Missing Episodes” selected, so we must contact tvdb
[2026-02-15 18:25:13.215] [info] [ethelper.js] (addRowToTmp) - tvdb aired selected for the show named node
[2026-02-15 18:25:13.215] [info] [tvdb.js] (getTVDBShowDVD) - Getting tvdb official info for 352440 with a title of: A Teacher
[2026-02-15 18:25:13.404] [error] [tvdb.js] (getTVDBShow) - Response error: [object Object]
Can you possibly help me figure out what the problem is?
Kind regards, Kimble
Sadly, development is paused for WebTools-NG
When said, I suspect a bug in it due to Specials have no entries, and maybe it can not handle that?
Sadly all I can suggest is that you (temporary) edit the show and select The Movie Database as the ordering and see if that helps
I hope you find time for this great project again. It really helps a lot of people. :heart_eyes:
By the way, your advice was a huge help. :slight_smile:
First of all, a big thank you for this often-useful tool.
Is there any chance that Webtools-NG will be ported so that it can continue to be used with Apple Silicon? I think many users would appreciate that.
Best regards
