Yes, I installed the latest nightly build. But flagging didn’t work.
Maybe I have to deinstall it, and make a “clean” reinstall with the nightly build?
I dont see how all of this is related to the plans for PLEX in the future…
I really hope the library is editable and has all the proper flags.
To get anything for XBMC I always go here and avoid hunting the forums: [http://www.sshcs.com/xbmc/](http://www.sshcs.com/xbmc/)
Did you turn on the scanning metadata button? You may need to start with a fresh copy of the latest app version and a new library to match.
PLEX and XBMC are both inexorably intertwined. And while PLEX's particular direction has always tried to be more Mac-like, I think both the applications will always have some interaction between the fan base as skins, plug-ins, features and changes are made in both.
Thanks for uploading those pictures. Seems like great mod to already great theme. I just might install XBMC for first time :-)
For XBMC support, please see the XBMC forums. Thanks
Enough said :)
With Snow Leopard coming out on Friday, is there any plans for Plex to take advantage of “Grand Central Dispatch” for multi-core processors? I think it would really help with making menus run a little snappier.
+1
If all you get from using social media is your friends' ■■■■ taking updates, you're doing it wrong.
I'd welcome a social networking layer to send and give recommendations to friends. Im sure if one would choose not to use these features that Plex would still work.
