def search(self, results, media, lang):
Log(‘zhanwei’)
Log(media.name)
dir(media)
the log is
2011-04-26 11:03:02,467 (1600) : INFO (core) - zhanwei
2011-04-26 11:03:02,467 (1600) : INFO (core) - ???2010
2011-04-26 11:03:02,482 (1600) : CRITICAL (core) - Exception in the search function of agent named ‘Douban’, called with keyword arguments {‘openSubtitlesHash’: ‘395dd460f4d96f37’, ‘name’: ‘\xe8\x8a\xb1\xe7\x94\xb0\xe5\x96\x9c\xe4\xba\x8b2010’, ‘filename’: ‘E:%5Cmedia%5C%E8%8A%B1%E7%94%B0%E5%96%9C%E4%BA%8B2010%2Ermvb’, ‘plexHash’: ‘1ca4dc7d2c4e7c4960578f45a6e90b8311317c65’, ‘duration’: ‘5294000’, ‘id’: ‘3’} (most recent call last):
File “C:\Documents and Settings\admin\Local Settings\Application Data\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\api\agentkit.py”, line 657, in search
agent.search(results, media, lang)
File "C:\Documents and Settings\admin\Local Settings\Application Data\Plex Media Server\Plug-ins\Douban.bundle\Contents\Code_init.py", line 24, in search
dir(media)
NameError: global name ‘dir’ is not defined
[size=“6”]
I want to know the attribute of a object how to ?[/size]
anyone can help me ?
Yep. dir() is restricted in v2 plug-ins for security reasons. If you want to know the names of properties an item has you can look at the source code in the Framework bundle. If you need to do runtime introspection you’re SOL unless you really want to write a v1 plug-in.
