Willing to code a plugin but there is no Guide! Please Help
Hi! I’m trying top develop my first plugin and followed the guide on wiki, but I had no results after few hours playing with it. Here is my code: I’m using Plex 8.0. Site configuration file is in Site config folder of plex media server, the strm file is on my desktop. Thanks for any help!!!
Site Config:
[codebox]<?xml version="1.0" encoding="UTF-8"?>
<site site="
http://www.tvn24.pl/wideo.html"
plugin=“http://.*.tvn24.pl/_d/wideo/flash/player_big_16x9_006.swf”
initialState=“playing”
version=“1.0”>
[/codebox]
tvn24.strm
[codebox]plex://localhost/video/:/webkit?url=http://www.tvn24.pl/2229932%2C0%2C0%2C1%2C1%2Ckryzys-i-polityka%2Cwideo.html[/codebox]
I had the same trouble … but here are a few pointers:
The Plug-in I wrote
This has relative good documentation … I tried to explain what I did at various steps in the process.
So the SITECONFIG is definitely the first step … look at the one I included in the plug-in.
Most of my troubles came from WRONG colors.
Here is a STEP by STEP plugin dev guide:
http://forums.plexapp.com/index.php?showtopic=5547
Look at the last post here for ENHANCED debug:
http://forums.plexapp.com/index.php?showtopic=6144
Hope this helps.
I get this error in terminal:
Request: GET /video/:/webkit?url=http%3A%2F%2Fwww.tvn24.pl%2Fwideo.html
	<event><br />
[/codebox]
and .strm file
[codebox]plex://localhost/video/:/webkit?url=http%3A%2F%2Fwww.tvn24.pl%2F2229922%2C0%2C0%2C1%2C1%2Cale-meksyk%2Cwideo.html[/codebox]
Thanks for helping me!!
It works! I’m very messy at coding and forgot to close some brackets:) Now the video plays and I’m eager to learn how to transform my work into a real plugin! Please point me to some threads where I can start with basics!
Thanks!
For others looking for some help don’t forget to:
  1. Open Console and navigate to Plex logs: they will update after you will try to load you config site and give you info what is wrong!
  2. Start this in Terminal: same as Console but a bit more specific! (it informed me of a missing bracket for example!)
    ~/Library/Application\ Support/Plex/Plex\ Media\ Server.app/Contents/MacOS/Plex\ Media\ Server
Hey failo.
Where could i find finished plugin?
