Wrong transcode device being used, resulting in error
Server Version#: 1.42.1.10069-cbf7ce637 (Forum preview build on TrueNAS)
Player Version#: Android TV 10.30.6.4151
My server has two GPUs in it: an AMD iGPU, and an Intel Arc B580. I’ve had transcoding working for a while in Plex, and I know Battlemage support isn’t working yet, so I want to continue using the AMD iGPU.
This is selected in the UI:
[Req#d02/Transcode/9840b171682a485e-com-plexapp-android] Preparing driver rsv for GPU AMD Cezanne [Radeon Vega Series / Radeon Vega Mobile Series]
[Req#d02/Transcode/9840b171682a485e-com-plexapp-android/DriverDL/rsv] Skipping download; already exists
This is reflected in the FFmpeg invocation:
[Req#d02/Transcode/9840b171682a485e-com-plexapp-android/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/5a45f5a-34a364f06232ef31ec8ebad0-linux-x86_64/' LIBVA_DRIVERS_PATH="/config/Library/Application Support/Plex Media Server/Cache/va-dri-linux-x86_64" X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 h264 -analyzeduration 20000000 -probesize 20000000 -i "/mnt/video/XXXXX.mkv" -start_at_zero -copyts -fps_mode cfr -init_hw_device vaapi=vaapi:/dev/dri/renderD129 -filter_hw_device vaapi -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/9840b171682a485e-com-plexapp-android/21e3e941-9932-4c73-b54c-2f73316837a6/progress -filter_complex "[0:0]scale=w=1920:h=1080:force_divisible_by=4[0];[0]format=pix_fmts=nv12[1];[1]hwupload[2]" -map "[2]" -metadata:s:0 language=eng -codec:0 h264_vaapi -b:0 20000k -maxrate:0 20000k -bufsize:0 40000k -bsf:0 extract_extradata -r:0 23.975999999999999 -sei:0 -a53_cc -force_key_frames:0 "expr:gte(t,n_forced*1)" -map 0:1 -metadata:s:1 language=eng -codec:1 copy -copypriorss:1 0 -segment_format matroska -f ssegment -individual_header_trailer 0 -flags +global_header -segment_header_filename header -segment_time 1 -segment_start_number 0 -segment_time_delta 0.0625 -segment_list "http://127.0.0.1:32400/video/:/transcode/session/9840b171682a485e-com-plexapp-android/21e3e941-9932-4c73-b54c-2f73316837a6/manifest?X-Plex-Http-Pipeline=infinite" -segment_list_type csv -segment_list_size 5 -segment_list_separate_stream_times 1 -segment_list_unfinished 1 -segment_format_options output_ts_offset=10 -max_delay 5000000 -avoid_negative_ts disabled -map_metadata:g -1 -map_metadata:c -1 -map_chapters -1 "media-%05d.ts"
The device, vaapi:/dev/dri/renderD129, is the correct card:
root@pandorica[~]# lspci | grep 30:00.0
30:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Vega Mobile Series] (rev dc)
root@pandorica[~]# ls -l /dev/dri/by-path | grep 129
lrwxrwxrwx 1 root root 13 Nov 23 20:06 pci-0000:30:00.0-render -> ../renderD129
However, playback fails with Intel-specific complaints from VAAPI, mirroring Battlemage errors:
[Req#df6/Transcode/9840b171682a485e-com-plexapp-android/21e3e941-9932-4c73-b54c-2f73316837a6] [AVHWDeviceContext @ 0x7f38fcd6ce40] libva: /config/Library/Application Support/Plex Media Server/Cache/va-dri-linux-x86_64/iHD_drv_video.so init failed
[Req#e11/Transcode/9840b171682a485e-com-plexapp-android/21e3e941-9932-4c73-b54c-2f73316837a6] [AVHWDeviceContext @ 0x7f38fcd6ce40] Failed to initialise VAAPI connection: 18 (invalid parameter).
[Req#e15/Transcode/9840b171682a485e-com-plexapp-android/21e3e941-9932-4c73-b54c-2f73316837a6] Device creation failed: -5.
[Req#e18/Transcode/9840b171682a485e-com-plexapp-android/21e3e941-9932-4c73-b54c-2f73316837a6] Failed to set value 'vaapi=vaapi:' for option 'init_hw_device': I/O error
[Req#e1b/Transcode/9840b171682a485e-com-plexapp-android/21e3e941-9932-4c73-b54c-2f73316837a6] Error parsing global options: I/O error
This seems like a bug - why is it even touching the Arc card (renderD128) enough to fail on initializing it?
If you care to experiment: Battlemage Support - #120 by chris_decker08
Let’s call that a partial success - on the one hand, transcoding is working again, on the other hand, it’s still ignoring my configuration and using the Battlemage card instead of the selected Cezanne iGPU
The new transcoder supports newer Intel CPUs & GPUs (BattleMage).
Support for AMD has not been completed yet.
The first step was to upgrade the main transcode and all Intel-centric GPUs
Chris will be adding AMD GPU support.
