Dec 21, 2018 21:29:19.480 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 5
Dec 21, 2018 21:29:19.480 [0x80d653d00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.480 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.480 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.480 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: false
Dec 21, 2018 21:29:19.480 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: false
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Pixel Encoding: 0
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Color Space: 0
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Refresh Rate: 50
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 4
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: false
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: false
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 1920x1080
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 3
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 1280x720
Dec 21, 2018 21:29:19.481 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 2
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: false
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: false
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Pixel Encoding: 0
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Color Space: 0
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Refresh Rate: 23.976023976023977
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 1920x1080
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 1
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 0
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] [Winvergo] getSupportedDisplayModes
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: true
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: true
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: true
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: true
Dec 21, 2018 21:29:19.482 [0x80d653d00] INFO - [ui-edge-winvergo] Pixel Encoding: 2
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Color Space: 2
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Refresh Rate: 59.94005994005994
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 12
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: true
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: true
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Pixel Encoding: 2
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Color Space: 3
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 11
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: true
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: true
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Refresh Rate: 50
Dec 21, 2018 21:29:19.483 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 10
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: true
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Pixel Encoding: 2
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Color Space: 3
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Refresh Rate: 50
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 9
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: true
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: false
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: false
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Color Space: 2
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Refresh Rate: 23.976023976023977
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 8
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: true
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Pixel Encoding: 1
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Bits Per Pixel: 30
Dec 21, 2018 21:29:19.484 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 7
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: true
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: true
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: true
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: true
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Pixel Encoding: 0
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Bits Per Pixel: 30
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Color Space: 2
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Refresh Rate: 23.976023976023977
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 6
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: false
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: false
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Color Space: 0
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Refresh Rate: 59.94005994005994
Dec 21, 2018 21:29:19.485 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 5
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Refresh Rate: 50
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 4
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: false
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: false
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Pixel Encoding: 0
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Color Space: 0
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 1920x1080
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 3
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 1280x720
Dec 21, 2018 21:29:19.486 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 2
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Pixel Encoding: 0
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Color Space: 0
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Refresh Rate: 23.976023976023977
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 1920x1080
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 1
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: false
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: false
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Display Mode: 0
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] [Winvergo] getSupportedDisplayModes
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Type: Playing
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] Status: 3
Dec 21, 2018 21:29:19.487 [0x80d653d00] INFO - [ui-edge-winvergo] [WinvergoSystemMediaTransportControls] setSMTCPlaybackStatus
Dec 21, 2018 21:29:19.488 [0x80b89b500] DEBUG - Completed: [10.10.0.120:50316] 200 POST /log (28 live) TLS GZIP 7ms 195 bytes (pipelined: 3)
Dec 21, 2018 21:29:19.502 [0x80b89ba00] DEBUG - Auth: authenticated user 1 as ME@ME.COM
Dec 21, 2018 21:29:19.502 [0x80d9b2c00] DEBUG - Request: [10.10.0.120:50316 (WAN)] POST /log (28 live) TLS GZIP Signed-in Token (ME@ME.COM)
Dec 21, 2018 21:29:19.503 [0x80d9b2c00] INFO - [ui-edge-winvergo] [WinvergoDisplayMode] Most compatible display mode set
Dec 21, 2018 21:29:19.503 [0x80d9b2c00] INFO - [ui-edge-winvergo] [Winvergo] setDisplayMode: Display mode already active
Dec 21, 2018 21:29:19.503 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.503 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports HDR: true
Dec 21, 2018 21:29:19.503 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: true
Dec 21, 2018 21:29:19.503 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: true
Dec 21, 2018 21:29:19.503 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: true
Dec 21, 2018 21:29:19.503 [0x80d9b2c00] INFO - [ui-edge-winvergo] Pixel Encoding: 2
Dec 21, 2018 21:29:19.503 [0x80d9b2c00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.503 [0x80d9b2c00] INFO - [ui-edge-winvergo] Color Space: 2
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Refresh Rate: 59.94005994005994
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Display Mode: 12
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: true
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: true
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Pixel Encoding: 2
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Color Space: 3
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Display Mode: 11
Dec 21, 2018 21:29:19.504 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports HDR: true
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: true
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: true
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: true
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Pixel Encoding: 2
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Color Space: 2
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Refresh Rate: 50
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Display Mode: 10
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Color Space: 3
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Display Mode: 9
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports HDR: true
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: false
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: false
Dec 21, 2018 21:29:19.505 [0x80d9b2c00] INFO - [ui-edge-winvergo] Refresh Rate: 23.976023976023977
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Display Mode: 8
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports Stereo: false
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports HDR: false
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: false
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: true
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: true
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Pixel Encoding: 1
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Bits Per Pixel: 30
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Color Space: 3
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Refresh Rate: 23.976023976023977
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Display Mode: 7
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Supports HDR: true
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SMPTE2084 Supported: true
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Pixel Encoding: 0
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Color Space: 2
Dec 21, 2018 21:29:19.506 [0x80d9b2c00] INFO - [ui-edge-winvergo] Display Mode: 6
Dec 21, 2018 21:29:19.507 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is SDR Luminance Supported: false
Dec 21, 2018 21:29:19.507 [0x80d9b2c00] INFO - [ui-edge-winvergo] Is 2086 Metadata Supported: false
Dec 21, 2018 21:29:19.507 [0x80d9b2c00] INFO - [ui-edge-winvergo] Pixel Encoding: 0
Dec 21, 2018 21:29:19.507 [0x80d9b2c00] INFO - [ui-edge-winvergo] Bits Per Pixel: 24
Dec 21, 2018 21:29:19.507 [0x80d9b2c00] INFO - [ui-edge-winvergo] Color Space: 0
Dec 21, 2018 21:29:19.507 [0x80d9b2c00] INFO - [ui-edge-winvergo] Refresh Rate: 59.94005994005994
Dec 21, 2018 21:29:19.507 [0x80d9b2c00] INFO - [ui-edge-winvergo] Resolution: 3840x2160
Dec 21, 2018 21:29:19.507 [0x80b89ba00] DEBUG - Completed: [10.10.0.120:50316] 200 POST /log (28 live) TLS GZIP 4ms 195 bytes (pipelined: 4)
Dec 21, 2018 21:29:19.638 [0x80b89ba00] DEBUG - Auth: authenticated user 1 as ME@ME.COM
Dec 21, 2018 21:29:19.639 [0x80d878d00] DEBUG - Request: [10.10.0.10:55687 (WAN)] GET /status/sessions (28 live) TLS GZIP Signed-in Token (ME@ME.COM)
Dec 21, 2018 21:29:19.639 [0x80d878d00] DEBUG - [Now] Adding 1 sessions.
Dec 21, 2018 21:29:19.643 [0x80b89ba00] DEBUG - Completed: [10.10.0.10:55687] 200 GET /status/sessions (28 live) TLS GZIP 4ms 5905 bytes (pipelined: 16)
Dec 21, 2018 21:29:19.685 [0x80d9aad00] DEBUG - Starting a transcode session gn9jnzsja2h1gf45pbblj82x at offset -1.0 (state=3)
Dec 21, 2018 21:29:19.758 [0x80d9aad00] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Dec 21, 2018 21:29:19.758 [0x80d9aad00] DEBUG - [Universal] Using local file path instead of URL: /media/Movies/Avengers Infinity War 2018/Avengers Infinity War (2018) REMUX3 2160p.mkv
Dec 21, 2018 21:29:19.758 [0x80d9aad00] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
Dec 21, 2018 21:29:19.759 [0x80d9aad00] DEBUG - Job running: EAE_ROOT='/tmp/pms-c4071ed8-232b-4877-bb42-f8109d8bc503/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/usr/local/plexdata-plexpass/Plex\ Media\ Server/Codecs/531e313-1328-freebsd-x86_64/' XDG_CACHE_HOME='/usr/local/plexdata-plexpass/Plex Media Server/Cache' XDG_DATA_HOME='/usr/local/share/plexmediaserver-plexpass/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/usr/local/share/plexmediaserver-plexpass/Plex Transcoder' '-codec:0' 'hevc' '-noaccurate_seek' '-probesize' '10000000' '-i' '/media/Movies/Avengers Infinity War 2018/Avengers Infinity War (2018) REMUX3 2160p.mkv' '-map' '0:0' '-metadata:s:0' 'language=eng' '-codec:0' 'copy' '-map' '0:1' '-metadata:s:1' 'language=eng' '-codec:1' 'copy' '-copypriorss:1' '0' '-f' 'dash' '-min_seg_duration' '5000000' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/manifest' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress'
Dec 21, 2018 21:29:19.771 [0x80d9aad00] DEBUG - Jobs: Starting child process with pid 73274
Dec 21, 2018 21:29:19.814 [0x80d9b2c00] DEBUG - Request: [127.0.0.1:32287 (Loopback)] PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress?status=startup (29 live) Signed-in Token (ME@ME.COM)
Dec 21, 2018 21:29:19.815 [0x80b89b500] DEBUG - Completed: [127.0.0.1:32287] 204 PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress?status=startup (29 live) 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Dec 21, 2018 21:29:19.815 [0x80d9b2c00] DEBUG - Request: [127.0.0.1:32287 (Loopback)] PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress?status=opening (29 live) Signed-in Token (ME@ME.COM)
Dec 21, 2018 21:29:19.816 [0x80b89b500] DEBUG - Completed: [127.0.0.1:32287] 204 PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress?status=opening (29 live) 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Dec 21, 2018 21:29:19.829 [0x80d653d00] DEBUG - Request: [127.0.0.1:32287 (Loopback)] PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress?status=opened (29 live) Signed-in Token (ME@ME.COM)
Dec 21, 2018 21:29:19.830 [0x80b89ba00] DEBUG - Completed: [127.0.0.1:32287] 204 PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress?status=opened (29 live) 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Dec 21, 2018 21:29:19.830 [0x80d653d00] DEBUG - Request: [127.0.0.1:32287 (Loopback)] PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress/stream?index=0&id=0&codec=hevc&type=video (29 live) Signed-in Token (ME@ME.COM)
Dec 21, 2018 21:29:19.830 [0x80b89ba00] DEBUG - Completed: [127.0.0.1:32287] 206 PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress/stream?index=0&id=0&codec=hevc&type=video (29 live) 0ms 256 bytes (pipelined: 4) (range: bytes=0-)
Dec 21, 2018 21:29:19.830 [0x80d653d00] DEBUG - Request: [127.0.0.1:32287 (Loopback)] PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress/stream?index=1&id=0&codec=ac3&type=audio (29 live) Signed-in Token (ME@ME.COM)
Dec 21, 2018 21:29:19.831 [0x80b89ba00] DEBUG - Completed: [127.0.0.1:32287] 206 PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress/stream?index=1&id=0&codec=ac3&type=audio (29 live) 0ms 256 bytes (pipelined: 5) (range: bytes=0-)
Dec 21, 2018 21:29:19.831 [0x80d9b2c00] DEBUG - Request: [127.0.0.1:32287 (Loopback)] PUT /video/:/transcode/session/gn9jnzsja2h1gf45pbblj82x/3654ec31-2620-45c6-ab9e-263c2afededd/progress/stream?index=2&id=0&codec=ac3&type=audio (29 live) Signed-in Token (ME@ME.COM)
