XML data in database
Hello. If I look in XML data of media, there is data about <Part accessible=“1” exists=“1” .
Is it possible to find this data in plex database? I can’t find the table which contains this data.
AFAIK, those are calculated on the fly, when looking up a media, and having checkFiles=1 as one of the parameters
But you can export a list, using 3rd. party tools like:
Ok, thx. I already tried with export tools, but the job was very slow and I aborted it. I’ll try with tautulli, if it will be any quicker. Otherwise I’ll just have to wait, now that I know that this data cant be found in database.
That’s normal. After all, it has to try and actually access the media file to make sure the results are correct.
If you do it for one movie, you’ll probably not notice. But for a whole library worth of items, it can take a while.
If you share what your end goal is & what you are trying to accomplish, there might be some other hints.
Building something?
Looking for Library entries with missing media?
Export 2 items with level all
Then create a custom level with just the fields you need, and it’ll be a lot faster
Trying to find items with missing media.
