xpath repeating values
I'm still newish to xpath and seem to be having a problem with a for loop. The loop is supposed to grab ID nums and show titles. I'm able to grab each ID num more or less fine, but for some reason the first show title found repeats for each iteration through the loop. If anyone has insight into why this is happening, I would love to hear it!
Here is my code:
@route(PREFIX + '/showprograms')
def ShowPrograms(title):
    oc = ObjectContainer(title2=title)
    pass_url = 'http://ww3.tvo.org/video?quicktabs_3=0'
    pageElement = HTML.ElementFromURL(pass_url)
    for item in pageElement.xpath('//div[@class="form-item"]'):
        testid = item.xpath('./input')[0].get('value')
        testtitle = item.xpath('//label')[0].text
        #using hardcoded data until error is resolved
        showIDFull = '120075'
        showTitle = 'A Touch of Frost'
        showID = showIDFull.replace('','')
        showURL = 'http://ww3.tvo.org/program/'+showID+'/'
        Log ('show id:' + testid)
        Log ('show title:' + testtitle)
        oc.add(DirectoryObject(key=Callback(ShowEpisodes, title=showTitle, pass_url=showURL), title=showTitle, summary='Add summary'))
    return oc
And here is a snippet from the log:
2014-03-22 01:34:41,328 (16c) :  INFO (core:598) - Started plug-in
2014-03-22 01:34:41,328 (16c) :  DEBUG (socketinterface:160) - Starting socket server
2014-03-22 01:34:41,372 (16c) :  DEBUG (runtime:1111) - Created a thread named 'start'
2014-03-22 01:34:41,374 (16c) :  INFO (socketinterface:184) - Socket server started on port 50384
2014-03-22 01:34:41,374 (16c) :  INFO (pipeinterface:25) - Entering run loop
2014-03-22 01:34:41,375 (16c) :  DEBUG (runtime:717) - Handling request GET /:/prefixes
2014-03-22 01:34:41,381 (16c) :  DEBUG (runtime:814) - Found route matching /:/prefixes
2014-03-22 01:34:41,470 (1244) :  DEBUG (services:362) - Loaded services
2014-03-22 01:34:41,473 (16c) :  DEBUG (runtime:918) - Response: [200] MediaContainer, 418 bytes
2014-03-22 01:34:41,476 (1338) :  DEBUG (services:438) - No shared code to load
2014-03-22 01:34:46,331 (27c4) :  DEBUG (runtime:717) - Handling request GET /video/tvo
2014-03-22 01:34:46,338 (27c4) :  DEBUG (runtime:814) - Found route matching /video/tvo
2014-03-22 01:34:46,338 (27c4) :  DEBUG (base:123) - Checking if com.plexapp.plugins.tvo is broken
2014-03-22 01:34:46,339 (27c4) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMjMKY29tLnBsZXhhcHAucGx1Z2lucy50dm9zMTAKaWRlbnRpZmllcnIwCg__'
2014-03-22 01:34:46,344 (267c) :  DEBUG (runtime:717) - Handling request GET /video/tvo/showprograms?title=Programs
2014-03-22 01:34:46,345 (267c) :  DEBUG (runtime:814) - Found route matching /video/tvo/showprograms
2014-03-22 01:34:46,345 (267c) :  DEBUG (networking:172) - Requesting 'http://ww3.tvo.org/video?quicktabs_3=0'
2014-03-22 01:34:46,369 (27c4) :  DEBUG (runtime:918) - Response: [200] MediaContainer, 829 bytes
2014-03-22 01:34:47,203 (267c) :  INFO (logkit:16) - show id:Search TVO...
2014-03-22 01:34:47,203 (267c) :  INFO (logkit:16) - show title:
            All
2014-03-22 01:34:47,204 (267c) :  INFO (logkit:16) - show id:Search All Videos
2014-03-22 01:34:47,206 (267c) :  INFO (logkit:16) - show title:
            All
2014-03-22 01:34:47,206 (267c) :  INFO (logkit:16) - show id:All
2014-03-22 01:34:47,207 (267c) :  INFO (logkit:16) - show title:
            All
2014-03-22 01:34:47,207 (267c) :  INFO (logkit:16) - show id:192225
            All
2014-03-22 01:34:47,207 (267c) :  INFO (logkit:16) - show id:120075
2014-03-22 01:34:47,209 (267c) :  INFO (logkit:16) - show title:
            All
2014-03-22 01:34:47,209 (267c) :  INFO (logkit:16) - show id:201118
2014-03-22 01:34:47,210 (267c) :  INFO (logkit:16) - show title:
            All
2014-03-22 01:34:47,210 (267c) :  INFO (logkit:16) - show id:120165
And so on…
Looks like the issue is that for the “testtitle” you’re using “//” in the xpath rather than “./” like in your “testid” xpath. The difference is that the latter forces the xpath to focus on children on the given node whereas the former is much less restrictive.
That did the trick. Thanks! I also had to change the anchor in "for item in pageElement.xpath('//div[@class="form-item"]'):" to make sure I only get relevant program data.
