Checking the schedule for tonight and quite a few shows have a yellow warning triangle next to them. This usually indicates a timing clash, but in this case it’s about half a dozen shows which follow each other, on the same channel so they cannot actually overlap. Also, I have the extra before and after time set to 0 for these so the times as shown in the program schedule all follow each other with no apparent overlap.
If I open one of the recordings, it doesn’t actually say there’s a clash. But it does display the warning triangle with no explanation.
So, what’s the point of a warning with no indication of what the problem is and why am I seeing this on several shows for which I can determine no problem?
Still seeing this myself. I thought it might be indicating that there’s already a copy of that episode in the library but that’s not the case here. Anyway, as far as I can tell, duplicate episodes don’t appear in the schedule unless you first delete the existing copy (or, I assume, the new recording is of higher resolution and you’ve selected to replace SD recordings).
Someone must know what those yellow warning triangles are. This sort of thing drives me mad. The developers create a nice little warning notice and then do not tell you what the actual problem is that you are being warned about. What’s the point of that?
