Server Version#: 1.18.2.2058-e67a4e892
Player Version#: 3.108.2
Upgraded from a full working and stable 1.16.5.1488-deeb86e7f to 1.18.2.2058-e67a4e892 via the web interface.
After the upgrading, scanning library and updating when adding a new entry causes the below error (table media_items has no column named color_trc).
Rolling back to 1.16.5.1488-deeb86e7f and everything is working again.
Nov 26, 2019 19:03:10.192 [6452] DEBUG - Added new metadata item () with ID 11373
Nov 26, 2019 19:03:10.207 [6452] ERROR - SQLITE3:0x10ccc04f, 1, table media_items has no column named color_trc in "insert into media_items (library_section_id,section_location_id,metadata_item_id,type_id,width,height,size,duration,bitrate,container,video_codec,audio_codec
Nov 26, 2019 19:03:10.207 [6452] ERROR - Exception inside transaction (inside=1) (…\Library\MetadataItem.cpp:3519): sqlite3_statement_backend::prepare: table media_items has no column named color_trc for SQL: insert into media_items (library_section_id,section_location_id,metadata_item_id,type_id,width,height,size,duration,bitrate,container,video_codec,audio_codec,display_aspect_ratio,frames_per_second,audio_channels,interlaced,source,hints,display_offset,settings,created_at,updated_at,optimized_for_streaming,deleted_at,media_analysis_version,sample_aspect_ratio,proxy_type,extra_data,channel_id,begins_at,ends_at,color_trc) values (:media_items_library_section_id,:media_items_section_location_id,:media_items_metadata_item_id,:media_items_type_id,:media_items_width,:media_items_height,:media_items_size,:media_items_duration,:media_items_bitrate,:media_items_container,:media_items_video_codec,:media_items_audio_codec,:media_items_display_aspect_ratio,:media_items_frames_per_second,:media_items_audio_channels,:media_items_interlaced,:media_items_source,:media_items_hints,:media_items_display_offset,:media_items_settings,:media_items_created_at,:media_items_updated_at,:media_items_optimized_for_streaming,:media_items_deleted_at,:media_items_media_analysis_version,:media_items_sample_aspect_ratio,:media_items_proxy_type,:media_items_extra_data,:media_items_channel_id,:media_items_begins_at,:media_items_ends_at,:media_items_color_trc)
Nov 26, 2019 19:03:10.207 [6452] ERROR - Exception assimilating media item in : sqlite3_statement_backend::prepare: table media_items has no column named color_trc for SQL: insert into media_items (library_section_id,section_location_id,metadata_item_id,type_id,width,height,size,duration,bitrate,container,video_codec,audio_codec,display_aspect_ratio,frames_per_second,audio_channels,interlaced,source,hints,display_offset,settings,created_at,updated_at,optimized_for_streaming,deleted_at,media_analysis_version,sample_aspect_ratio,proxy_type,extra_data,channel_id,begins_at,ends_at,color_trc) values (:media_items_library_section_id,:media_items_section_location_id,:media_items_metadata_item_id,:media_items_type_id,:media_items_width,:media_items_height,:media_items_size,:media_items_duration,:media_items_bitrate,:media_items_container,:media_items_video_codec,:media_items_audio_codec,:media_items_display_aspect_ratio,:media_items_frames_per_second,:media_items_audio_channels,:media_items_interlaced,:media_items_source,:media_items_hints,:media_items_display_offset,:media_items_settings,:media_items_created_at,:media_items_updated_at,:media_items_optimized_for_streaming,:media_items_deleted_at,:media_items_media_analysis_version,:media_items_sample_aspect_ratio,:media_items_proxy_type,:media_items_extra_data,:media_items_channel_id,:media_items_begins_at,:media_items_ends_at,:media_items_color_trc)
