Version 1.18.0.1944
Using Arch Linux, installed via AUR
Up to date according to Public channel
I’m running into this problem as well, but none of the suggestions seem to be working here.
The error (shown at all steps):
what(): sqlite3_statement_backend::prepare: no such column: library_sections.content_changed_at for SQL: select library_sections.id as 'library_sections_id', library_sections.library_id as 'library_sections_library_id', library_sections.name as 'library_sections_name', library_sections.name_sort as 'library_sections_name_sort', library_sections.section_type as 'library_sections_section_type', library_sections.language as 'library_sections_language', library_sections.agent as 'library_sections_agent', library_sections.scanner as 'library_sections_scanner', library_sections.user_thumb_url as 'library_sections_user_thumb_url', library_sections.user_art_url as 'library_sections_user_art_url', library_sections.user_theme_music_url as 'library_sections_user_theme_music_url', library_sections.created_at as 'library_sections_created_at', library_sections.updated_at as 'library_sections_updated_at', library_sections.scanned_at as 'library_sections_scanned_at', library_sections.user_fields as 'library_sections_user_fields', library_sections.query_xml as 'library_sections_query_xml', library_sections.query_type as 'library_sections_query_type', library_sections.uuid as 'library_sections_uuid', library_sections.changed_at as 'library_sections_changed_at', library_sections.content_changed_at as 'library_sections_content_changed_at' from library_sections
****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /root/Library/Application Support/Plex Media Server/Crash Reports/1.18.0.1944-f2cae8d6b/PLEX MEDIA SCANNER/69390c96-cd17-c741-38cf14fa-6b329091.dmp
Trying to delete the index as shown above:
sqlite> .indices metadata_items
index_metadata_items_on_absolute_index
index_metadata_items_on_added_at
index_metadata_items_on_changed_at
index_metadata_items_on_created_at
index_metadata_items_on_deleted_at
index_metadata_items_on_guid
index_metadata_items_on_hash
index_metadata_items_on_index
index_metadata_items_on_library_section_id
index_metadata_items_on_library_section_id_and_metadata_type_and_added_at
index_metadata_items_on_metadata_type
index_metadata_items_on_original_title
index_metadata_items_on_originally_available_at
index_metadata_items_on_parent_id
index_metadata_items_on_remote
index_metadata_items_on_resources_changed_at
index_metadata_items_on_title
index_metadata_items_on_title_sort
index_title_sort_naturalsort
sqlite> DROP INDEX ‘index_title_sort_naturalsort’;
Error: no such index: ‘index_title_sort_naturalsort’
sqlite>
So sqlite can both see and not see the index in question. Really weird. I proceed with database repair:
[root@umbra Databases]# systemctl stop plexmediaserver
[root@umbra Databases]# rm com.plexapp.plugins.library.db
[root@umbra Databases]# cp com.plexapp.plugins.library.db.original com.plexapp.plugins.library.db
[root@umbra Databases]# rm dump.sql
[root@umbra Databases]# sqlite3 com.plexapp.plugins.library.db "DROP index 'index_title_sort_naturalsort'"
[root@umbra Databases]# sqlite3 com.plexapp.plugins.library.db "DELETE from schema_migrations where version='20180501000000'"
[root@umbra Databases]# sqlite3 com.plexapp.plugins.library.db .dump > dump.sql
[root@umbra Databases]# sqlite3 com.plexapp.plugins.library.db < dump.sql
[root@umbra Databases]# chown plex:plex com.plexapp.plugins.library.db
[root@umbra Databases]# mv com.plexapp.dlna.db-shm com.plexapp.dlna.db-shm.old
[root@umbra Databases]# mv com.plexapp.dlna.db-wal com.plexapp.dlna.db-qal.old
[root@umbra Databases]# systemctl start plexmediaserver
No errors, great. Let’s try to run the scanner again:
[root@umbra Databases]# /usr/lib/plexmediaserver/Plex\ Media\ Scanner --list
terminate called after throwing an instance of 'soci::soci_error'
****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /root/Library/Application Support/Plex Media Server/Crash Reports/1.18.0.1944-f2cae8d6b/PLEX MEDIA SCANNER/72ea1c60-134d-eb5c-7477ca91-188061ac.dmp
Error in command line:the argument for option '--serverUuid' should follow immediately after the equal sign
The statement in question however works fine running manually in sqlite:
sqlite> select library_sections.id as 'library_sections_id', library_sections.library_id as 'library_sections_library_id', library_sections.name as 'library_sections_name', library_sections.name_sort as 'library_sections_name_sort', library_sections.section_type as 'library_sections_section_type', library_sections.language as 'library_sections_language', library_sections.agent as 'library_sections_agent', library_sections.scanner as 'library_sections_scanner', library_sections.user_thumb_url as 'library_sections_user_thumb_url', library_sections.user_art_url as 'library_sections_user_art_url', library_sections.user_theme_music_url as 'library_sections_user_theme_music_url', library_sections.created_at as 'library_sections_created_at', library_sections.updated_at as 'library_sections_updated_at', library_sections.scanned_at as 'library_sections_scanned_at', library_sections.user_fields as 'library_sections_user_fields', library_sections.query_xml as 'library_sections_query_xml', library_sections.query_type as 'library_sections_query_type', library_sections.uuid as 'library_sections_uuid', library_sections.changed_at as 'library_sections_changed_at', library_sections.content_changed_at as 'library_sections_content_changed_at' from library_sections;
1||Movies||1|en|com.plexapp.agents.imdb|Plex Movie Scanner||||2018-11-22 02:13:05|2019-07-26 17:18:52|2019-10-17 23:35:43|pr%3AcollectionMode=1&pr%3AenableCinemaTrailers=0&pv%3AlastAddedAt=1555798380|||97cced92-9c96-4a38-b154-5c2a2ba2ea1a|2286939|0
2||TV Shows||2|en|com.plexapp.agents.thetvdb|Plex Series Scanner||||2018-11-22 02:14:10|2019-07-26 17:19:23|2019-10-17 23:35:48|pv%3AlastAddedAt=1555798380|||f454765f-6b28-4083-b912-ca25fa42b62e|2286995|0
4||Music||8|en|tv.plex.agents.music|Plex Music||||2018-12-31 08:17:06|2019-07-26 17:19:04|2019-10-17 23:35:44|pv%3AfirstLoudnessScan=0&pv%3AlastAddedAt=1555798380|||b4c6d553-c608-4cca-9edb-c92f3226fc61|2286960|0
6||Anime||2|en|com.plexapp.agents.thetvdb|Plex Series Scanner||||2019-04-06 16:03:03|2019-07-26 17:18:10|2019-10-17 23:35:40|pv%3AlastAddedAt=1555798380|||75581c50-2a46-4149-9609-cba98e3bdc84|2286886|0
7||B List Movies||1|en|com.plexapp.agents.imdb|Plex Movie Scanner||||2019-04-13 03:52:34|2019-07-22 21:25:03|2019-10-17 23:35:41|pv%3AlastAddedAt=1555798380|||3c5e4194-397d-4c51-94dc-2df8a175c680|2089162|0
8||Anime Movies||1|en|com.plexapp.agents.imdb|Plex Movie Scanner||||2019-05-07 10:29:12|2019-08-10 01:29:38|2019-10-17 23:35:41|pr%3AcollectionMode=1|||2875f37b-4c61-4925-8fd3-6f100a79b79e|2576030|0
9||Classical Movies||1|en|com.plexapp.agents.imdb|Plex Movie Scanner||||2019-05-07 10:30:27|2019-07-22 21:24:53|2019-10-17 23:35:42||||531ad207-6d45-4e6e-882b-34736629a025|2089161|0
10||Soundtracks||8|en|tv.plex.agents.music|Plex Music||||2019-05-10 23:47:02|2019-07-26 17:19:10|2019-10-17 23:35:45|pv%3AfirstLoudnessScan=0|||3f75a5ec-f808-47b8-b7f3-16ab65d5ab76|2286970|3601920
12||Family Movies||1|en|com.plexapp.agents.imdb|Plex Movie Scanner||||2019-05-22 12:48:24|2019-07-22 21:25:14|2019-10-17 23:35:43|pr%3AcollectionMode=1|||154cce01-60d8-4c0e-9ddc-3b1e7bcd2527|2089166|0
13||Audiobooks||8|en|tv.plex.agents.music|Plex Music||||2019-05-22 16:39:05|2019-07-26 17:18:22|2019-10-17 23:35:41|pv%3AfirstLoudnessScan=0|||74dacb42-af53-474f-9168-04cd78fe8fc1|2286928|0
14||MST3K and Rifftrax||1|en|com.plexapp.agents.imdb|Plex Movie Scanner||||2019-05-22 21:31:22|2019-07-22 20:56:57|2019-10-17 23:35:44|pr%3AcollectionMode=1|||181a5844-7c58-48d7-8edf-341f27d502e8|2087944|0
15||Documentaries||1|en|com.plexapp.agents.imdb|Plex Movie Scanner||||2019-05-28 11:25:51|2019-07-22 21:24:36|2019-10-17 23:35:42||||f7d79e75-4d9f-4582-850c-a8a7d4c5c952|2089148|0
16||Docuserials||2|en|com.plexapp.agents.thetvdb|Plex Series Scanner||||2019-08-27 13:03:59|2019-08-27 13:03:59|2019-10-17 23:35:43||||b714ade9-a1e6-4c99-8d80-26034b1f4f24|2911795|0
And the server log (a bit truncated):
Oct 18, 2019 09:30:50.698 [0x7f696c0f9b80] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.26.0, threadsafe=1
Oct 18, 2019 09:30:50.739 [0x7f696c0f9b80] DEBUG - Running migrations. (EPG 0)
Oct 18, 2019 09:30:50.739 [0x7f696c0f9b80] DEBUG - Running forward migration 20180501000000.
Oct 18, 2019 09:30:50.739 [0x7f696c0f9b80] DEBUG - Captured session 0.
[repeat 19 times for sessions 1-19]
Oct 18, 2019 09:30:50.792 [0x7f696c0f9b80] DEBUG - Analyzing database.
Oct 18, 2019 09:30:50.965 [0x7f696c0f9b80] DEBUG - Vacuuming database.
Oct 18, 2019 09:30:52.390 [0x7f696c0f9b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
[repeat 18 times]
Oct 18, 2019 09:30:52.424 [0x7f696c0f9b80] DEBUG - Completed forward migration 20180501000000.
Oct 18, 2019 09:30:52.451 [0x7f696c0f9b80] DEBUG - ChangestampAllocator: initialized to 3610746
Oct 18, 2019 09:30:52.451 [0x7f696c0f9b80] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.26.0, threadsafe=1
Oct 18, 2019 09:30:52.455 [0x7f696c0f9b80] DEBUG - Running migrations. (EPG 0)
This is the last place migrations are mentioned in the log.
Sort of at a loss here. I could rebuild the entire server structure by deleting the database, but that both deletes all the view history (which I would like to avoid) and doesn’t tell me why it happened or how to fix it in the future.
Any further ideas are appreciated.
