Yes, that’s enough to show me what’s happening.
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Selected protocol dash; container: mp4
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: analyzing media item 1966871
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Avengers: Endgame (2019): Direct Play is disabled
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Avengers: Endgame (2019): media must be transcoded in order to use the dash protocol
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Avengers: Endgame (2019): no direct play video profile exists for http/mkv/hevc
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Avengers: Endgame (2019): no direct play video profile exists for http/mkv/hevc/truehd
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Avengers: Endgame (2019): no direct play video profile exists for http/mkv/hevc/ac3
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Avengers: Endgame - video.bitDepth limitation applies: 10 > 8
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Avengers: Endgame - audio.channels limitation applies: 8 > 6
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Avengers: Endgame (2019): Direct Streaming is disabled, so video stream will be transcoded
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Avengers: Endgame (2019): no remuxable profile found, so video stream will be transcoded
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Codecs: testing h264_nvenc (encoder)
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Codecs: hardware transcoding: testing API nvenc
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] ERROR - [Transcode/et7gkcp95w9ak7et8547exad] [FFMPEG] - Cannot load libcuda.so.1
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] ERROR - [Transcode/et7gkcp95w9ak7et8547exad] [FFMPEG] - Could not dynamically load CUDA
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Unknown error occurred
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Could not create hardware context for h264_nvenc
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Cannot direct stream video stream due to profile or setting limitations
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Codecs: testing hevc (decoder) with hwdevice vaapi
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Codecs: hardware transcoding: testing API vaapi
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] ERROR - [Transcode/et7gkcp95w9ak7et8547exad] [FFMPEG] - libva: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] ERROR - [Transcode/et7gkcp95w9ak7et8547exad] [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: I/O error
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Could not create hardware context for hevc
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Codecs: testing hevc (decoder) with hwdevice nvdec
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Codecs: hardware transcoding: testing API nvdec
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Scaled up video bitrate to 184594Kbps based on 4.500000x fudge factor.
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] Scaled maximum bitrate for resolution reduction to 64835Kbps.
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Avengers: Endgame (2019): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Cannot direct stream audio stream due to profile or setting limitations
Jan 25, 2022 17:04:14.518 [0x7f6178cd2b38] DEBUG - [Transcode/et7gkcp95w9ak7et8547exad] MDE: Avengers: Endgame (2019): selected media 2 / 1966871
If you’re comfortable SSH into the QNAP as admin (must be ‘root’).
- Verify QTS sees the card
/sbin/gpuhal_app -l
- Look at the ID value (the hex digit in the first column of the output)
gpuhal_app -s ID_NUMBER_HERE
It will return
– driver_installed=1 status if a valid driver is found
– real_status=2 status if the card is in QTS mode.
When both conditions are satisfied, the path to the drivers is given to PMS (for the CUDA drivers)
PMS will then know how to access it.
