2018 Mac Mini Having Issues Transcoding (Lots of Buffering)
Server Version#: 1.14.0.5468
Player Version#: iOS 5.7.1
I got a souped up new Mac Mini last week with a 6-core i7 and 32GB of RAM. Thus far we’ve been pretty disappointed by the results. We seem to be having a lot more issues with buffering than we had with the 2011 Mac Mini Server.
plex-logs.txt (327.4 KB)
^^ Here is a log from a recent attempt to stream a movie remotely from iOS. The key errors I’m seeing include:
  • ClientProfileExtra: video transcode target already exists for streaming hls
  • MDE: unable to find a working transcode profile for video stream
  • MDE: no compatible media decisions are available
Any advice? We are starting to regret our decision to upgrade to this new Mac Mini but I’m hopeful that there has to be a logical solution to the problem.
EDIT: I’m also seeing this error, which is not likely related:
Nov 25, 2018 16:04:26.383 [0x700005230000] ERROR - [FFMPEG] - Try -allow_sw 1. The hardware encoder may be busy, or not supported.
I thought the T2 in the new Mac Mini was supposed to support hardware decoding? For now I’m going to turn hardware acceleration OFF.
Hi, try the latest not beta version. I’m running a 2018 Mac mini, i5 with only 8GB and Plex Version 1.13.9.5456 … no buffering issues so far. Yesterday I tried the beta version, the CPU usage shot through the roof … so I reverted.
I’m mostly always on beta and haven’t seen this issue, very happy with the new mini.
I’m running into the same issue/same machine. Its not so much buffering I’m seeing as it simply stops randomly. Did reverting help you?
I believe Marco Arment, developer of macOS podcast player Overcast notes in his review of the 2018 Mini that ffmpeg needs some values modified to enable the T2 hardware decoder.
https://marco.org/2018/11/06/mac-mini-2018-review
" But if an app supports the T2’s hardware HEVC encoder,[3] it can go much faster."
The [3] links to " ffmpeg can do it by specifying -c:v hevc_videotoolbox instead of -c:v x265 . I also needed -vtag hvc1 for the output MP4s with either codec to be playable on macOS.
Compressor uses the T2’s HEVC acceleration when encoding 8-bit HEVC, but not 10-bit."
