Plexamp Release Notes
Plexamp v4.50.20-beta.29
This one rolls up the last few betas. Desktop is on the beta channel now, Android is in Play testing, and iOS is in TestFlight.
Added
  • The experimental Chromecast receiver is now available to everyone: Settings › Remote Control › Use Experimental Receiver, then restart Plexamp.
  • Caldera players’ settings can take a file, so you can import an AutoEQ profile as an EQ preset or upload a room-correction filter (needs a Caldera beta that isn’t out yet).
Fixed
  • Switching libraries from CarPlay or Android Auto works again.
  • CarPlay: no more crash or freeze when playback starts just as it connects, such as from a Shortcut.
  • CarPlay: shuffling an album opened from the Home screen plays it instead of loading forever.
  • Fixed a crash while another device is fetching a file from Plexamp.
  • Visualizers should line up better with what you hear, including over Bluetooth and AirPlay.
  • A section’s › sits beside its title instead of at the far edge.
  • Compilations are listed by title, with the full A-Z bar.
  • Rows in sorted library lists are evenly spaced.
  • An artist’s Similar Artists rows follow the page’s Grid or List setting.
  • Windows: fixed a crash at launch for some people.
  • macOS: keys work as soon as the window opens, without a click first.
  • Linux: the cursor no longer gets stuck as a resize arrow.
  • Desktop: album pages sit on the cover’s own colors, and an artist’s background art spans the top of the page without flickering.
  • Desktop: the sidebar meets the player bar without a seam, and arrowing left lands on the right row.
