Plexamp v4.50.9
Desktop is on the stable channel now. TestFlight is available, and the Play build is still in review.
Everywhere
- Album art no longer stalls the app on very large downloaded playlists.
Mobile
- Long menus scroll again. Sort options at the bottom of the list, like Random, were unreachable.
- The Add to Collection list scrolls, so you can reach collections beyond the first few alphabetically.
- Grids no longer blink between a cover’s blurred placeholder and the cover itself. (Android)
- Scrolling quickly through a grid no longer shows the previous item’s cover in a cell before the right one appears. (Android)
- The play/shuffle/filter bar on album, artist and track grids sits flush under the header again instead of floating a strip below it. (iOS)
- That bar’s background now uses the same material as the header, so the two read as one surface.
- The header is a little taller on iOS 26, so the back button’s capsule no longer touches its bottom edge. (iOS)
- Writing a share to an NFC tag works again. The option had vanished from the share menu entirely. (iOS)
Desktop
- The Windows now-playing panel shows the track, artist and cover again instead of just “tv.plex.plexamp”.
- The Linux Flatpak runs on a current GNOME runtime. Installing it warned that the one it used had stopped being supported back in March.
