3D Play Sort without separate Library
Didn't see this in the search.
Would like to see 3D search and play 3d, non 3d version.
Currently we have to create a separate library.
You can always have two copies in the same library and change the name or some tag to be 3D that you will be able to filter by.
[sharedmedia=core:attachments:21495]
There are other feature requests like this already however that would be all encompassing for things like Directors cut, Theatrical cut , alternate ending, 3d, 2d, 1080p, SD, 4k and any other reason you may have two copies of the same movie. the request is basically you pick the movie then it asks you which of the versions to play
this is the most upvoted one so far so you should probably vote for this one as to not split votes. https://forums.plex.tv/topic/46113-very-popular-multiple-cuts-of-movie/
I already requested this feature. See this thread: https://forums.plex.tv/topic/117687-feature-request-3d-at-a-glance/
Done and Done.
