Hi everyone, noob here.
I currently have an 8TB hard drive that is just about full. I have 2 10TB hard drives on the way, for a total of 28TB. I believe additional video files will yield approximately 5TB, for a total of 13TB used of 28TB total. I also have a 4-drive Probox on the way. My end goal is to stream movies via Plex (on a Roku TV) in my apartment.
I would appreciate feedback on the best way to setup the drives and to protect the files from drive failure. As far as setting up, I was contemplating parity via Raid 5, but I’ve read that reconstructing a failed driver can lead to additional drive failure and permanent loss of data. @cayars recommended using DrivePool to group the drives into one and SnapRAID for redundancy: here. That was almost two years ago, and I’m unclear if this is still the best route to follow and if so, how to set these drives up in DrivePool so that they are grouped together but not via RAID (like what settings would I be looking for), and then how to integrate SnapRAID into the process. I would ideally like one massive drive to work from, the date of which is reasonably protected should drive failure occur.
Last, I’m not sure of the best way to backup the files. Is mirroring recommended, or the duplicate option in DrivePool? Or should I just upload everything to an online service - if so, is any particular one recommended?
Really appreciate the help!
