@jjrjr1 said:
@Elijah_Baley
So the transfer to using Drive Pool will be transparent, sort of. Right?
All I should have to do is point libraries at the new Drive Pool drive??
I will be installing DP on the PMS box. What issues are there with that??
With DP setup, will Plex still see the discrete HDDs while DP is installing and or doing it’s thing.
In other words, I will be able to access all my HDDs with a single drive designation but will I still be able to access them directly/individually??
Thanks for the info.
To answer your last questions first, yes, but with a few caveats.
Plex can still see all the drive just as it does now, again with a few caveats.
The only two issues I ran into with DP and PMS on the same computer was the computer was slow to startup sometimes and sometimes the DrivePool service did not start requiring a reboot to get it going. Those could have bee mainly because the computer was probably a but under-powered for the combined tasks.
Now to address the first parts and the caveats I mentioned.
When you install DrivePool it creates a hidden sub-directory on each drive you put it the pool. Those sub-directories are linked and form the pooled drive which is given a new drive letter. Any content that is not in one of the hidded subdirectory on one of the pooled drives is not in the pool and is not managed by DrivePool.
The best way, or at least the fastest, to get your content into the pool is to go onto each drive and move the content into that hidden sub-directory on that drive. Directly moving the content like that is fast but moving content from a drive to the DrivePool drive goes through the system just like moving from one drive to another so it is much slower. Once you do that the content shows up in the Pool but it still can be directly accessed as well by simply going into that hidden sub-directory but, once the content is in the pool accessing it through the DrivePool drive is the best way.
The DrivePool drive behaves exactly like any other windows drive and can even be shares on the network and is seen by Plex as just another drive.
One more suggestion is that you install the “Load Balance” plugin and duplicate your media folders as desired (If you ever change the name of a duplicated folder you will have to set the duplication on it again) and then let DrivePool do all the work. Do not try to micromanage DrivePool, just let it work for you.
DrivePool does protect you very well from a single drive failure but it does not protect from your own deletions so be kind of careful as you move stuff around.
I hope the above helps some.
BTW: StableBit’s forums are pretty good and my experience that any requests for help get answered within 24 hours, usually less, by one of the developers.
Edit: One more thing - DrivePool never will erase your content during install or setup.
