Hi guys,
has rasplex the possibility to work at 4K resolution? I’ve raspberry pi b+ (single core version) and a 4k tv by hisense.
After that, anyone with this model xt880 I can’t use the CEC function with raspberry, suggestions about that?
thanks
Your TV or receiver will upscale from 1080 to 4K, but it can’t decode above 1920x1080 video streams in hardware, so…
Scroll down, there are all the possible output modes, be aware that settings these manually could cause issues if they are not supported by your TV.
thanks for your reply, otherwise I’ve test the manal settings with my 4k tv. It works fine, but the raspberry hardware can’t upscale the video from 1080p to 4k so it’s better to use 1080p than 4k. At the moment no solution for CEC.
CEC differs from TV to TV, better to use an IR remote, best is RemotePi Board from MSL Digital, supported in Rasplex without any configuration.
Regards
