7.7.0.7305 crashes on Playback
Server Version#: 1.13.4.5251-2e6e8f841
Player Version#: 7.7.0.7305
Plex on my tablet just updated and now I don’t seem to be able to play anything - the app crashes as soon as I hit play :frowning:
Updated server to 1.13.8.5395-10d48da0d, same problem :frowning:
Sorry for talking to myself, but it looks like this device may be “stuck” in the beta channel, even though I’m sure I opted back out. Any ideas anyone?
Just dont install betas. The public android version is unstable enough to be considered beta.
Well, I’ve had to buy another Plex Pass, started applying to rejoin the Beta program, and so found a link to leave it. Not hugely impressed with that!
I can report that now I’ve managed to downgrade, everything is OK again. So beta is buggy :slight_smile:
Device, which I should have posted earlier, is Samsung Galaxy Tab A 7, SM-T280. Android 5.1.1.
I am told, this is the link to opt out from the beta program.
It should be the same you used to opt in.
https://play.google.com/apps/testing/com.plexapp.android
Would you be able to grab some logs from 7.7 so we can investigate the issue?
I can try, but can’t promise - “real world” stuff stupidly crazy at the moment.
Is there an idiot’s guide to grabbing the logs you need - client or server side or both?
https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
