A problem has been detected with a core component of Plex Media Server
Server Version#:
I recently did a clean install of Windows 11 so needed to set up my plex server again. After installing plex server and then going to the web-link to set it up, i was hit with “A problem has been detected with a core component of Plex Media Server.”
I tried uninstalling plex media server, deleting app data, and reinstalling but I’m still getting the above error.
I’m not sure what log i need to attach so i attached them all
Hope you can help! THanks much
Logs.zip (282.1 KB)
Had the same issue, heres how i solved it.
Downgraded the server to an older installer i had(1.29.0.6244) and it installed fine and setup actually stuck, Apon updating to latest there has been no issue since.
There is a bug with the current update and the setup.
I am sure if you googled it, you should get a site that archives it otherwise i would guess to wait till a new update comes out.
