A problem has been detected with a core component of Plex Media Server
Trying to install Plex Media Server on a Mac Mini. The processor exceeds minimum specs. I’ve attempted to install, uninstalled, and attempted to install again. Same error as set forth in the subject line. Here is the Plex Media Server log. (There’s also a “Plex Crash Uploader.log” in case that helps. Thanks in advance for any help:
[Plex Media Server.log|attachment](upload://sQTQNSntKTt1NAy5BLDfpTwM5Eu.log) (213.4 KB)
Solved my issue. In case anyone else is looking for help on this, it didn’t have anything to do with my Mac or its components. It was just a bad Plex build.
Solution: Google around to find an old Plex media server build. In my case, I found a build from January 2023. I downloaded that, installed it, and Voila! Everything works perfectly. Most probably know that they should not allow updates to be applied until Plex kicks out a more stable build. If you update, you’re likely to end up back in the same boat.
