A problem has been detected with a core component of Plex Media Server
Just downloaded both Plex app and Media server. Plex app opens with the error in the title every time; trying to open the media server does absolutely nothing. I’ve found several other posts here and elsewhere with people having the same issue but haven’t seen any solutions or explanations. I’ve tried both the 64- and 32-bit versions and have the same issue with each.
Server Version#: v.1.42.1.10054-f333bdaa8
Logs.zip (1.1 MB)
We are aware of the problem and are already looking into it. Right now I am collecting reports and information (your report is one of them) and we have people looking into this issue. Thank you for the report, we will have more information as soon as it is available.
I have the same issue, and was hopeful that the problem was newly introduced with the latest version (as of Aug 9th 2025), but I see this error has been around for years. I spent hours and hours yesterday trying to rectify with clean installs etc etc, to no avail. Might try and older version today. But I have never had such issues in the 15 years or so I’ve been running Plex? Grateful for advice, as I’m not convinced the version is the issue
Hello,
had the same issue with the .exe installer from website. But after some tests i think i have found a workaround. Used the “download from microsoft store” way, this worked fine. After installed then an update was offered and also after update all is running fine at the moment, i mean plex media server can be setup and started successfully. I think this is only a temporary workaround.
Server Version#:PlexMediaServer-1.42.1.10054-f333bdaa8-x86_64
OS System: Windows 10 Pro 64 bits
I attach server logs without the possibility to configure verbose type. The error triggered when I just tried to configure the server and it says:
“It has been detected a issue witha Plex Media Server Core Component”
“Se ha detectado un problema con un componente del núcleo de Plex Media Server.”
What should I do? Thanks in advance for your help!!
Regards
Plex Media Server.log (786.8 KB)
Moderator Edit: Consolidating your post into an existing thread. @FordGuy61
Also, update and workaround from Plex:
Same problem here now server is not rechable. I tried deleting and reistalling plex media server. Can’t reach server. Can you just delete the account and juct create another account? If that is possise will I still get my Lifetine Plex Pass with the new account?
I have the same error.
A problem has been detected with a core component of Plex Media Server.
Please visit the forums and provide your logs, as described here.
This was a new raspberry pi system where the OS was installed same day. I believe this is a problem in the latest build. I setup another R PI a week ago with the same config and this error did not come up. I can provide logs if needed.
All good with v.1.42.1.10060 Many thanks! all good now
