Server Version#: Version 1.19.4.2902
x265 files buffer often other types of files do not can you help fix this?
can you provide more specific details?
what clients?
what is your server hardware?
what is your network?
what does the dashboard or tautulli show for a problem video? screenshot?
server logs? Plex Web > settings > troubleshooting > download logs > drop the whole zip into a reply
4k ? see @ Plex, 4k, transcoding, and you
how do i get the logs to you/? and my hard ware is a D link ax very new router and windows 10 pro desktop 3ghz dual core intel and 8gigs of ram
the logs Plex Media Server Logs_2020-06-08_20-34-11.zip (6.0 MB)
drop the zip file into the reply window
are you trying to play videos through the web browser?
or are you using plex for windows, or plex media player (2 different windows players)
or is the windows desktop for the plex server?
playing thru ps4 app
coming from my desktop sever to my ps4
x264 avc high bit rate files stream just fine it x265 1080p and 720p that buffers
I am no playstation4 expert, but from other posts in the forum, its is horrible for plex.
based on these logs, it appears ps4 is not compatible with the audio so it is being transcoded, and if subtitles are enabled, that could cause the video to be transcoded, which hevc can overload your server trying to transcode.
Jun 08, 2020 19:21:17.385 [10128] DEBUG - MDE: E1 - Destiny, the Chosen Ones: media must be transcoded in order to use the hls protocol
Jun 08, 2020 19:21:17.385 [10128] DEBUG - MDE: E1 - Destiny, the Chosen Ones: no direct play video profile exists for http/mkv/hevc
Jun 08, 2020 19:21:17.385 [10128] DEBUG - MDE: E1 - Destiny, the Chosen Ones: no direct play video profile exists for http/mkv/hevc/opus
Jun 08, 2020 19:21:17.385 [10128] DEBUG - MDE: E1 - Destiny, the Chosen Ones: no remuxable profile found, so video stream will be transcoded
Jun 08, 2020 19:21:17.385 [10128] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Jun 08, 2020 19:21:17.386 [10128] DEBUG - Scaled up video bitrate to 6111Kbps based on 4.500000x fudge factor.
Jun 08, 2020 19:21:17.386 [10128] DEBUG - Codecs: testing aac_mf (encoder)
Jun 08, 2020 19:21:17.389 [10128] INFO - [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Jun 08, 2020 19:21:17.393 [10128] DEBUG - MDE: Cannot direct stream audio stream due to codec opus when profile only allows aac
Jun 08, 2020 19:21:17.393 [10128] DEBUG - MDE: Kämpfer - S1 E1 - Destiny, the Chosen Ones: selected media 0 / 80849
Jun 08, 2020 19:21:17.393 [10128] DEBUG - Streaming Resource: Adding session 0xb042070:tzcrl68arvtfeytg1jp0md9b which is using transcoder slot. Used slots is now 1
Jun 08, 2020 19:21:17.393 [10128] DEBUG - Streaming Resource: Added session 0xb042070:tzcrl68arvtfeytg1jp0md9b
Jun 08, 2020 19:21:17.394 [10128] DEBUG - Streaming Resource: Reached Decision id=73971 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=80849 part=(id=81274 decision=transcode container=mpegts protocol=hls streams=(Video=(id=170437 decision=transcode bitrate=6111 encoder=libx264 width=1920 height=1080) Audio=(id=170438 decision=transcode bitrate=256 encoder=aac_mf channels=2 rate=48000))))
Jun 08, 2020 19:21:17.395 [6088] DEBUG - Completed: [192.168.0.166:54447] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F73971&mediaIndex=0&partIndex=0&protocol=hls&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&directStreamAudio=1&mediaBufferSize=51200&session=a4zzxsfo3jzw668nn4xqc41p&subtitles=burn&Accept-Language=en (7 live) GZIP 247ms 1432 bytes (pipelined: 4)
in particular
the hevc is being transcoded to x264
converting hevc takes a lot of cpu, depending on how new/old your cpu is, can make a huge difference if the cpu is strong enough.
is the windows task manager showing 100%?
if you have subtitles turned on, you can try disabling them to see if the video will direct play.
will a graphics card help?
possibly, but gpu transcoding requires plexpass.
secondly, ideally you want to avoid transcoding in the first place.
thirdly, you can buy a roku 4k for cheap and probably have better luck for less cost than gpu+plexpass.
Here’s one even cheaper than that:
$69 for the Roku Flagship?
Why doesn’t everyone have one of these?
(I have two)
so i can use the plex app on roku 4k whats the set up?
