I have downloaded a 4K UHD movie (around 45GB) and I am trying to play it on my Plex but I am not able to get it to work properly. When I play the movie for first time it takes like 3~4 min to load. Even if it start as 4K and a good quality after a few minutes and intermittently the movie lost the original quality and looks ugly a few seconds after I got a message saying the network and/or the computer are not fast enough to play such file.
However I am able to play the movie locally using the web application and it goes fine at “4k” with no gaps.
Here is a few things that might help to fix and/or understand my issue and give me a recommendation:
CPU:
Cores: 6
Threads: 12
Name: Intel Core i7 5820K
Specification: Intel Core i7-5820K CPU @ 3.30GHz
RAM:
32GB DDR4
Video:
Model: nVidia GeForce GTX 970
Memory: 4095 MB
About the downloaded movie:
Format : Matroska
Format version : Version 4 / Version 2
File size : 48.4 GiB
Overall bit rate mode : Variable
Overall bit rate : 58.6 Mb/s
Writing application : mkvmerge v27.0.0 ('Metropolis') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Commercial name : HDR10
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 58 min
Bit rate : 43.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.221
Stream size : 36.2 GiB (75%)
Writing library : ATEME Titan File 3.8.16 (4.8.16.0)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 4 746 kb/s
Maximum bit rate : 7 335 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Delay relative to video : 32 ms
Stream size : 3.92 GiB (8%)
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 13
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate : 4 058 kb/s
Channel layout : C L R LFE Lb Rb Lss Rss
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Delay relative to video : -1 ms
Stream size : 3.35 GiB (7%)
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 31 ms
Stream size : 541 MiB (1%)
Language : English
Service kind : Complete Main
Default : No
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Bit rate : 320 kb/s
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 270 MiB (1%)
Language : English
Default : No
Forced : No
Audio #5
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Bit depth : 16 bits
Language : French
Default : No
Forced : No
Audio #6
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Format profile : Blu-ray Disc
Codec ID : A_EAC3
Bit rate : 1 024 kb/s
Stream size : 865 MiB (2%)
Language : French
Default : No
Forced : No
Audio #7
Format : E-AC-3
Codec ID : A_EAC3
Language : Spanish
Default : No
Forced : No
Audio #8
Format : E-AC-3
Codec ID : A_EAC3
Language : German
Default : No
Forced : No
Audio #9
Format : E-AC-3
Codec ID : A_EAC3
Language : Italian
Default : No
Forced : No
It’s possible to play this movie on my PC? Do I need to change any settings on my Plex Server?
