AC-3 (Dolby Digital) Audio
Can Plex play AC-3 (Dolby Digital) Audio, I have a few LOTR TV Shows that will not play the audio, video is ok!!
I am using the Apple TV 4K and also does not work on PC using Windows Media Player and VLC
If it will not play in Window Media Player or VLC, then something is probably wrong with the files.
Ok, you try downloading The Lord of the Rings The Rings of Power S02E03 and see how you go!!
