ACC Audio Transcode Broken - Again
PMS : 1`.43.3.10828 - ACC audio transcoder broken.
A related post says Live TV Streams PMS 1.43.3.10828 broke Live TV streams with AAC audio
I have hundreds of files in my PMS that use ACC audio, I can play them back no problem when direct streaming on devices (android or Windows). I tried to downgrade to 1.43.2.10687 but still have the same issue there.
Is this only for Live TV streams or anytime you transcode a file with AAC? Regardless, can you please do the following:
  1. Confirm server DEBUG logging is enabled, VERBOSE logging is disabled.
    SAVE if changes.
  2. Restart PMS
  3. Give it two minutes to start and stabilize
  4. Start a playback which shows the issue
  5. Let it play for 20 seconds
  6. Stop the playback
  7. Download the server logs
  8. Attach the logs so I may see them.
