Server Version#: Version 1.41.2.9200
It appears that when Plex optimized my MKV files that contained subtitles and captions, that the subtitles and captions are no longer included in the files.
Using MediaInfo I looked at the original MKV, the Plex Optimized - Original Quality and the Plex Optimized for TV quality files and notice that it appears that the captions are not included.
How do I get plex to include the captions? This is important for accessibility.
Original MKV FILE
General
Unique ID : 200099236274448564358049768585612345197 (0x9689B60A957B60F999F8D5C970BDBF6D)
Complete name : /Volumes/homes/plex/Media/TV Shows/Star Trek The Next Generation (1987)/Season 01/STAR TREK The Next Generation - S01E01 - Encounter At Farpoint.mkv
Format : Matroska
Format version : Version 2
File size : 17.4 GiB
Duration : 1 h 31 min
Overall bit rate mode : Variable
Overall bit rate : 27.2 Mb/s
Frame rate : 23.976 FPS
Movie name : STAR TREK The Next Generation Season 1
Encoded date : 2023-11-19 20:13:34 UTC
Writing application : MakeMKV v1.17.5 darwin(x64-release)
Writing library : libmakemkv v1.17.5 (1.3.10/1.5.2) darwin(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Format settings, Slice count : 4 slices per frame
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 20.4 Mb/s
Maximum bit rate : 38.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.411
Stream size : 13.0 GiB (75%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate : 5 028 kb/s
Channel(s) : 8 channels
Channel layout : C L R LFE Lb Rb Lss Rss
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.21 GiB (18%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 986 MiB (6%)
Title : Surround 5.1
Language : English
Default : No
Forced : No
Audio #3
ID in the original source medium : 4353 (0x1101)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Format settings : Dolby Surround
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel layout : L R
Frame rate : 31.250 FPS (1536 SPF)
Delay relative to video : 83 ms
Stream size : 125 MiB (1%)
Title : Stereo
Language : English
Service kind : Complete Main
Default : No
Forced : No
Dialog Normalization : -27 dB
compr : -0.28 dB
dsurmod : Dolby Surround encoded
mixlevel : 281 dB
roomtyp : Small
dialnorm_Average : -27 dB
dialnorm_Minimum : -27 dB
dialnorm_Maximum : -27 dB
Text
ID in the original source medium : 4608 (0x1200)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 29 min
Bit rate : 37.2 kb/s
Frame rate : 0.448 FPS
Count of elements : 2416
Stream size : 23.9 MiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:01:44.312 : en:Chapter 02
00:07:06.092 : en:Chapter 03
00:14:35.624 : en:Chapter 04
00:27:29.272 : en:Chapter 05
00:36:01.075 : en:Chapter 06
00:47:09.535 : en:Chapter 07
00:57:02.794 : en:Chapter 08
01:06:20.017 : en:Chapter 09
01:11:42.548 : en:Chapter 10
01:18:24.157 : en:Chapter 11
01:30:17.245 : en:Chapter 12
General
Complete name : /Volumes/homes/plex/Media/TV Shows/Star Trek The Next Generation (1987)/Season 01/Plex Versions/Optimized for TV/Star Trek_ The Next Generation/S01E01.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/dby1/iso2/avc1/mp41)
File size : 6.02 GiB
Overall bit rate : 9 435 kb/s
Writing application : Lavf59.20.101
Video
Format : AVC
Format profile : Main@L4
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 7 747 kb/s
Maximum bit rate : 8 000 kb/s
Frame rate : 23.976 (23976/1000) FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.156
Stream size : 4.94 GiB (82%)
Writing library : x264 core 161
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x1:0 / me=hex / subme=0 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=4 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=8000 / vbv_bufsize=16000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Language : English
Codec configuration box : avcC
Audio #1
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Source duration : 1 h 31 min
Bit rate : 741 kb/s
Maximum bit rate : 768 kb/s
Frame rate : 46.875 FPS (1024 SPF)
Stream size : 484 MiB (8%)
Source stream size : 484 MiB (8%)
Language : English
Default : Yes
Alternate group : 1
Audio #2
Format : AAC LC
Bit rate : 741 kb/s
Language : English
Default : No
Alternate group : 1
Audio #3
Format : AC-3
Codec ID : ac-3
Bit rate : 192 kb/s
Stream size : 125 MiB (2%)
Source stream size : 125 MiB (2%)
Language : English
Default : No
Alternate group : 1
compr : -0.28 dB
mixlevel : 281 dB
roomtyp : Small
Plex Original Quality
General
Complete name : /Volumes/homes/plex/Media/TV Shows/Star Trek The Next Generation (1987)/Season 01/Plex Versions/Original Quality/Star Trek_ The Next Generation/S01E01.mp4
Format : MPEG-4
File size : 11.5 GiB
Overall bit rate : 18.0 Mb/s
Video
Format : AVC
Codec ID : avc1
Bit rate : 16.3 Mb/s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.328
Stream size : 10.4 GiB (91%)
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x1:0 / me=hex / subme=0 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=4 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio #1
Format : AAC LC
Bit rate : 741 kb/s
Stream size : 484 MiB (4%)
Source stream size : 484 MiB (4%)
Language : English
Default : Yes
Alternate group : 1
Audio #2
Format : AAC LC
Bit rate : 741 kb/s
Language : English
Default : No
Alternate group : 1
Audio #3
Format : AC-3
Codec ID : ac-3
Bit rate : 192 kb/s
Source stream size : 125 MiB (1%)
Language : English
Default : No
Alternate group : 1
compr : -0.28 dB
mixlevel : 281 dB
roomtyp : Small
