Add advanced Custom Filter options such as codec and container format
Request: Add advanced Custom Filter options so that I can easily find and optimize all episodes that use a certain codec or are in a specific container format. The ability to see advanced options should be controlled with a toggle as is done in other areas, since I’m sure not all users would want to see every available field.
Use case: Some streaming devices don’t play nicely with certain codecs and/or formats. I would like to automatically create optimized versions for such files, but there’s no way to do that based on the currently available options in the Custom Filter.
Like this one?
Yup, except more broadly applicable. :wink:
My search obviously wasn’t very good before posting (because I was unintentionally searching in the Features forum rather than in Feature Suggestions), but I think my suggestion would be more useful than that one, which is limited to codecs. Thanks for that link. Since that suggestion is more than a year old with only one vote, I’m not holding my breath on this. Regardless, I added the above in a comment on that existing suggestion.
