Just got forced to update PlexConnect because of the SSL channel thing.
Noticed in the new version there was no more sorting by first letter. I have a lot of TV Shows (almost 400) so going through "All Shows" or searching sucked.
So I added it back.
Easy way
**Wont let me attach for some reason :( **
Grab the file from this link:
http://sdrv.ms/16Syg3t
Rename your original to TVSecondary.bak (Just in case)
Place it on your Server (Under ./assets/templates/TVSecondary.xml)
This will add the "By First Letter" sort under "More..."
Manual way
Very loose instructions:
1 - Make a copy of ./assests/templates/TVSecondary.xml
2 - Edit the file and search for a sort you want to replace (Or copy a current one)
Below is the original:
{{TEXT(By Content Rating)}}
{{URL(key)}}/contentRating?X-Plex-Container-Start=0&X-Plex-Container-Size=25&PlexConnect=SectionPreview
3 - Change anywhere is says "contentRating" to "firstCharacter"
After:
{{TEXT(By First Letter)}}
{{URL(key)}}/firstCharacter?X-Plex-Container-Start=0&X-Plex-Container-Size=25&PlexConnect=SectionPreview
**Should be in there 4 times. And don't forget to change the
