Add "Frame Rate" column to Table View
I wish there was a column for framerate, e.g., 25fps, 60fps…
Two tools that can provide the information:
WebTools NG: You can export the desired information in a CSV file. There are preset levels or you can create a custom report with only the desired fields.
Tautulli: Can display on-screen or export.
MediaInfo report for one of my libraries:
Thanks, that’s cool. I still wish it were built in :slight_smile:
