"Add playlist to home page" missing from Roku UI
Server Version#: 1.18.3.2129
Player Version#: 6.4.9.6153
When UNO first appeared on the Roku, I was thrilled to see that I could add playlists to the Home page, and I have had it configured that way ever since. I requested, and have been waiting, for this feature to be added to the UNO apps on other platforms, assuming that the feature would be coming to all.
But it appears that instead of adding the feature to all platforms, it was removed from the Roku.
Please put it back. I don’t put any of the hubs on the Home page, and this feature was the ONLY reason I have tolerated the Photo/Audio/Video tabs on the Playlists page.
This should not have been removed. I can still add a playlist hub from the Recommended tab from playlist screen. To add hubs to home, you must manually mage your home screen. This can be toggle from the HOME options in the menu bar.
Yeah, someone pointed it out to me on Slack. It didn’t occur to me to look there. However, that only allows me to add the ‘recommended’ hubs, like ‘recently played,’ ‘recently added.’ I used to be able to add just ‘Playlist.’
I really liked it better when all the playlists were on one tab.
EDIT: Now that the Playlists page has been split into Video, Music, and Photo tabs, there is no ‘Recommended’ tab anyway.
@beckfield
Per your request, I have re-opened.
Sadly, this is just getting worse.
First the option to add the static Playlists to the home page was removed, but the playlists that had been added were still there.
Now, I switched over to try the new design, and when I switched back to Manually managed, my static playlists on the home page are gone.
I know, ‘manually managed’ is going away soon. This is just one of many reasons I am NOT happy about it.
I want to know how to select what I wanna see in HomePage too. I did last week but now I don’t remember how I did, could you help me? thank you
Still not happy about this change. I wish I could add the static Playlist lists (NOT ‘recent playlist’ hubs) to the home page, like I used to have.
