YouTube has begun rolling out the av1 coding standard on its videos. At least one video downloader passes this through to the final file, making it incompatible with Plex until converted to a compatible format (can be done with VLC). Adding this open, royalty-free video coding format, would retain compatibility going forward
Incompatible with which Plex player(s)?
I verified the problem with Android TV (my main TV viewing platform) before I posted. (Version 7.28.0.15501, as reported by the device.)
Yep, got the same issue across all my devices, (Android, Debian, Windows). I used HandBrake to convert them to h.264, but this is pretty annoying as it takes forever copy files to my main computer, convert them and then copy them back. To be fair, enough modern media players nowadays still donât support av1.
Came here to post the same. Grabbed you new YouTube videos and theyâre all encoded with AV1. Plex needs to support this codec.
Fyi, Emby has no problems playing AV1 videos.
I didnât mean to imply PlexDev was deficient in any way. But if we donât ask for the feature, theyâll never know some of us want it.
Also have the same issue, on both Plex for Desktop and Plex on Android.
I have the same issue, Plex canât play AV1 videos but VLC does for the records.
PlexDev, we want to see our favourite Plex able to play AV1 videos so please fix it in your future updates.
Thanks.
Bump.
+1 for this.
AV1 could be direct played in web browsers, really looking forward to have the server support this codec.
+1
This would be great
They are probably waiting waiting until AV1 is in itâs final stage before implementing it. That being said I would like to see this feature soon.
Bothersome to have good quality content that you canât play back.
âCannot convert this item. Implementation for video decoder âav1â not found.â
+1
I would like this Feature for codec AV1
Please Please Please add AV1 support.
Also requesting AV1 support
Another request for AV1 support from me. Thanks
Another bump
+1 for needing av1 support
+1 for AV1 support in Plex
