Add to Watchlist only with previews
Many things do not have previews, so isolating Add to Watchlist there is a poor idea.
Put Add to Watchlist on the page of the item.
And, btw, all the “agents” are enabled.
Not sure what you mean by “previews” here. are you talking about trailers?
Do you have “Allow matching to explicit content” enabled for your movie library
Unfortunately that does not appear on a good bit of content.
like what sorta content
Fair, specifically while watching a trailer.
Yes, “Allow matching to explicit content” is enabled.
it wont show if it is
Movies is my boggle. For example: “The Hound of the Baskervilles” circa 2000.
Hmm … very well then. I’ll try disabling it. Thanks.
That appears to have been the problem.
Thank you for your time and most excellent pointer.
