Watchlist Management
Server Version#: 1.41.8.9834
Player Version#: 4.148.0
How is it possible that I have no option to remove an item from the Watchlist inside the item details??
Any ideas? Am I missing something? Thanks!!
I’m guessing because you have “Allow matching to explicit content” enabled in our TV library settings
The watchlist button will be right next to the Play/Resume button.
True! I turned off in the movies library and forgot to do it for the Series library. Any ETA when this will be fixed? Thanks.
Do your libraries contain porn?
Sure.
It is intentional that when that is setting is enabled to hide the watchlist. It is due to how things can potentially bubble up as related.
Understood. Thanks
