Added recently
Hello,
I just wanted to know if there is a way to remove the “added recently” section without removing the “in progress” section.
( I already know that we can disable the “include to the dashboard” in the Library edit )
Thanks for your help,
Majestyk :slight_smile:
Up, someone has an Idea ?
You can remove it from the home screen on the Android and iOS mobile apps. You cannot from other apps at this time.
Ok, thanks you ! That’s why I couldn’t remove it from the windows app :smile:
