Please add a keyboard shortcut for Guest DJ in Plexamp for Windows, so that you can select any DJ with a given key combination, or a hotkey or function for Node-RED.
Currently I use Home Assistant to control my Plexamp through Node-RED, so instead of a keyboard shortcut, a function could be added so that I can select it from Node-RED. For example "Guest DJ ": "DJ Twofer" but it doesn’t work now, only shuffle playback works "shuffle": "1".
