Adding a library language (for metadata)
What is needed to add a language for the library?
My language is not in the list of languages and therefore I'm not able to get the metadata that is available on TMDB in my language.
I've been using XBMC for years but PLEX is much more up to my needs apart from this issue.
Which language is missing in this case?
Icelandic :)
I've passed along the request.
Thanks a lot :)
Any news on this? - I believe I have waited quite calm for a loooong time now ;)
Isn't it just a matter of adding one language code to the source of available languages for tmdb?
Hi :slight_smile:
Please add Icelandic to the TMDB language options. I’ve been waiting almost two years for this simple update. The language code is “IS”.
I’ve bumped our internal issue about this. That said, I checked several super big/popular movies on TheMovieDatabase and none of them had an Icelandic version listed. Is there actually Icelandic content on TMDB?
@brjann.jonsson said:
Isn’t it just a matter of adding one language code to the source of available languages for tmdb?
And, no, it’s more involved than just adding a language code, unfortunately.
Yes there is a lot of Icelandic content and I would be happy to add a lot more my self. I also suspect that the local community of Plex users would do so also as soon as you add the language :slight_smile:
Can you please link to a few specific examples where items are available in Icelandic on the site?
Hi Chris
Here are a few examples I found:
Thank you for the examples. Star Wars VII definitely did not have Icelandic available previously because that’s one of the “super big/popular” movies mentioned earlier that I checked.
Apparently some local guy must have translated it recently (so there are more than me). I translated a few other popular movies after I sent you the list (from the popular section; Popular Movies — The Movie Database (TMDb)). And as I said, I’ll definitely translate hundreds as soon as the Icelandic library version is available - except you want it done prior to adding it in Plex :wink:
In any case, thanks for considering and taking time to explore this :slight_smile:
Any news on this now 18 months after you bumped up the issue?
