Hello,
adding downloaded epg.xml file brings the error above.
Here is the excerpt from logs:
Nov 24, 2019 21:30:03.485 [0x7f79e67fc700] ERROR - XML: Entity: line 259342:
Nov 24, 2019 21:30:03.485 [0x7f79e67fc700] ERROR - XML: parser
Nov 24, 2019 21:30:03.485 [0x7f79e67fc700] ERROR - XML: error :
Nov 24, 2019 21:30:03.485 [0x7f79e67fc700] ERROR - XML: internal error: Huge input lookup
Nov 24, 2019 21:30:03.485 [0x7f79e67fc700] ERROR - XML: aide de la Stasi. Elle vivra dans la peur constante d'ГЄtre dГ©masquГ©e. Ce qui
Nov 24, 2019 21:30:03.485 [0x7f79e67fc700] ERROR - XML: ^
Nov 24, 2019 21:30:03.549 [0x7f79527fc700] ERROR - XML: Entity: line 259342:
Nov 24, 2019 21:30:03.549 [0x7f79527fc700] ERROR - XML: parser
Nov 24, 2019 21:30:03.549 [0x7f79527fc700] ERROR - XML: error :
Nov 24, 2019 21:30:03.549 [0x7f79527fc700] ERROR - XML: internal error: Huge input lookup
Nov 24, 2019 21:30:03.549 [0x7f79527fc700] ERROR - XML: aide de la Stasi. Elle vivra dans la peur constante d'ГЄtre dГ©masquГ©e. Ce qui
Nov 24, 2019 21:30:03.549 [0x7f79527fc700] ERROR - XML: ^
Nov 24, 2019 21:30:03.595 [0x7f79527fc700] ERROR - Error parsing content from "/home/plex/tvguide/plextv/guide.xml".
Nov 24, 2019 21:30:03.630 [0x7f79e67fc700] ERROR - Error parsing content from "/home/plex/tvguide/plextv/guide.xml".
Nov 24, 2019 21:30:03.630 [0x7f79e67fc700] ERROR - Error parsing XML: Error parsing file.
Nov 24, 2019 21:30:03.630 [0x7f79e67fc700] DEBUG - EPG: Computing channel mapping.
Plex server version - 1.18.2.2058
Size of the file is 22MB.
Here is the link of EPG_XML file.
Thank you in advance.
