DVR empty - MediaProviders exception
Server Version#: 1.25.5.5492-12f6b8c83
Tuner Make/Model: Hauppauge
Using XMLTV?: Yes
I’m trying to load an EPG xml file and the guide never displays. Looking at the logs, I see this error:
Feb 07, 2022 15:50:35.531 [0x7f0719258b38] ERROR - Exception inside transaction (inside=1) (/data/jenkins/server/3535999200/MediaProviders/EPG/XMLTV/MediaProviderEpgXmlTv.cpp:693): bad lexical cast: source type value could not be interpreted as target
Feb 07, 2022 15:50:35.532 [0x7f0719258b38] ERROR - EPG[xmltv]: Caught exception during data chunk load: bad lexical cast: source type value could not be interpreted as target
Feb 07, 2022 15:50:35.532 [0x7f0719258b38] WARN - EPG[xmltv]: Failed to load EPG.
The xml file used is http://xmltv.net/xml_files/Melbourne.xml and it has worked previously without any problems.
Any ideas where to start with debugging this error?
Plex Media Server Logs_2022-02-07_15-51-42.zip (1.2 MB)
So was a slightly mixed up xml file. Plex’s error text is not that useful though for debugging!
