Adjust gamma with kb/remote
Is there a way to access mpv’s keyboard controls to adjust gamma on the fly? I can’t settle on a decent level going from SDR to all the mastering levels in HDR. In mpv’s documentation they say keys 5 and 6 will raise and lower the gamma. Can I access this via plex htpc? It didn’t seem to work when I tried it.
You can set your own keyboard mappings. See Plex HTPC Input Maps | Plex Support which mentions how you can create a mapping to send commands directly to MPV. See mpv.io for the full list of supported commands/properties.
