Adjusting recording lengths by seconds (not just minutes)?
Is there any capacity for adjusting scheduled recording length by seconds rather than by minutes? I see the options for “start early” and “end late”, but the number box only works in minutes. I tried decimal (i.e., I want to run the recorder 15 seconds later, so I enter 0.25 in the minutes box) but that wasn’t accepted. I assume that presently there is not such an option.
There’s one American TV network that runs everything on a delay of approx 10-15 seconds, and without the option to extend recording by a few seconds, I end up missing the last few moments of shows (which are usually still in dialog). Simply adding a minute doesn’t help as then it holds one of my two available tuners up past the half-hour or hour point, resulting in skipped recordings (or recordings missing the entire first minute, if I allow partials). It shouldn’t take much to change the code to allow seconds, or even decimal minutes in the early & late timing fields.
