Admin Account Need Password?
Does my Admin account need to have a password? Getting tired of having to enter it each time. I trust the other profile I have on it. (I know I can create yet another profile - don’t want to)
All regular accounts need a password.
Are you using the browser? If you have it set to clear cookies/site data when browser quits then it will not save the log in info
If you only mean the 4 digit PIN code on the switch user screen you can set auto-login which will bypass the PIN and log into last signed in user. In the web app in browser it is in the General settings.
But you don’t need the pin if you don’t want it. In the account Plex Home settings, on your accounts row click on Edit PIN which will have you enter it once then when the blank boxes appear to choose a new PIN, instead click Remove on the bottom left of boxes
Thanks, yes sorry, I’m looking to remove the PIN on my admin account, but don’t want any account to auto login. So, each time I open it - on Apple TV - I just want anyone to be presented with the account list, and then choose whichever, with NO PIN needed on any, including the admin account. I can’t find the setting you mentioned when I log into the web version.
Nevermind, found it. Thanks!
