[adult] data18.com Metadata Agent - Release
@wickedluva I have only seen that problem when data18 throttles your IP, or more or less bans it from searches.
Try doing from the same IP a search in data18.com
I typically find that I have to use a VPN :frowning:
@halkon I have the same issue using VPN. I use PIA for a VPN.
An example is below. i know its on data18 website but as you see no results are found. i provided screenshots
I see, try doing this:
I permanently have the Plex Server through some policy based routing to always go to data18 through the VPN. (PIA too +1)
Let me know if that helps.
@halkon any new updates for the data18 movie bundle to try?
@e_dub I’m sorry I forgotten, with the holidays and vacation time I pretty much forgot, I’ll get back to it this week, apologies for the delay
I’v made some change on my side to your script.
  • I’v made change to handle the release date when it is not in a link
  • For the studio field, I look first for a studio, then for a site if a studio is not found and last for a network.
  • I use the network (if found) for the collection (but this last one is more a personnal preference than an enhancment).
You can find my version here if you want to check it.
No worries @halkon thanks for checking it out this week.
@RyoSaeba75 thanks for the updates! I’ll create a PR in github and try it out
@e_dub I created a PR against the Movie Plugin:
Sadly I don’t have push access to it, or else it would have been released, the fixes are there, if you want to download the update and try it manually:
https://github.com/frankieon/Data18.bundle/archive/fix-studio-director-genre-collections.zip
Boom!! @halkon you rock! I saw on github that it was made part of the package so I updated via the Unsupported App Store. It works perfectly! Threw 11 movies at it so far and each one is right. Cast, Studio, Director, Genres, Collection. This is hands down the best adult agent now.
I wonder. Is there a way to add Trailer support now that Plex has that? Could the trailer be pointed to the data18 trailer, if there was one?
I’m curious about that, the problem would be that it links to other sites sometimes, but perhaps, that may be something we can look at :smiley:
@RyoSaeba75 created a PR that you can see here with your changes, however I did omit using the network as the collection, and I switched parsing the studio to go Studio > Network > Site.
The reasoning for that is typically the studios are the network and not the sites, however I’m not opposed to travel down the chain like that because there are sites that are networkless.
Let me know what you think:
Noob question?
How do I update??
How can I tell I successfully updated??
For the Data18.bundle, you would see studio, genre, director, and collection matches (previously not working)
for Data18-Content, matching movie scenes will now give you a studio as well, let me know if that helps @braveflamingo
hello plugin data content 18 don’t working
Btas Katrina Jade Bb121814 480p 2000----->http://www.data18.com/content/1149935
don’t scrapper no title no poster Nothing
No associated files
nothing
@phantom972 it needs to be named Exchange of Favors (2015) for it to be matched, it won’t match BTAS or the BB121814
thanks
SO I have to manually renamed all my videos on my pc ?
Sadly yes, data18 has no metadata available in regards to the original IDs from the sites, so BB121814 means nothing to it.
The only way the agent can actually match anything is by doing a search on data18.com and seeing the titles that come up on that search, we are at the mercy of the data18.com search, sorry :frowning:
I will say, I am not entirely sure about this but: https://forums.plex.tv/discussion/61808/nfo-local-files-problem talks about using nfo files to read the data, not sure how that works with the matching as well. May want to look at that?
