[adult] PhoenixAdult - Multisite Adult Metadata Agent - Development
I sent you a PM @Crankzii
Missax has no search, so once again I’d have to build a searchable database. I will eventually build a setup for searching all these sites, just kinda a low priority. Would rather knock out the ones first that don’t rely on me providing any infrastructure for access.
Working mostly great so far! Have noticed some older (years 2007-2008 noticed so far) Brazzers scenes having trouble grabbing posters and genres (actresses/scene info come in fine). Any known limitations there? An example scene would be “Big Butts Like It Big - Another Bad Review”.
Thanks for this awesome work! Any plans to add Interracialpass.com/Hushpass.com?
Awesome Job on the plug-in!!! you rock.
Any chance for digitalplayground to be added?
Thanks for the great job works like a charm. Two things I noticed:
ExposedCasting I do not get any hits at all
Further if there is a chance on the Porndoe that it would except the date as well when it is like YY MM DD would be great right now it must be YYYY MM DD
Keep on doing it !!!
I’m having problems with the agent unfortunately. I get super weird matches when I try to use it. I even copied some of the examples and get mismatches. Every time. Haven’t had a single match that looks correct. Does anyone know why this could be?
The site I’m mostly trying to match with is Girlsway.
Thanks for you hard work!
I download a girls way video there and named it ‘GirlsWay - Squirting Surprise’ and it matched correctly.
make sure your only using the titles not the porn stars names or dates.
When I try searching for exactly what you said “GirlsWay - Squirting Surprise”, I just get a scene called “Quick Learner, A [Jun 19, 2015]”. Which is a completely different scene.
I have added agents before, without any issues. I’ve also re-downloaded this agent and installed it again. No luck. Really don’t understand what I’m doing wrong here. :frowning:
Update: Looks like I’m only getting complete “movies”, not scenes from GirlsWay. Is this a known issue?
Sorry guys, I’m pretty tied up working lately.
@Edeke I think you are using my Data18-Phoenix plugin, not my PhoenixAdult plugin. That is a result from Data18-Phoenix you just showed.
@Spanishu I am doing some quick work to do the two digit year matching right now. Seems to be working. I’m investigating the odd behavior with Exposed Casting as well. I will post when a update is uploaded.
I’m stupid! Didn’t see that they were named differently. Thanks for the (super) quick answer!
Thanks for all your hard work PhoenixUser! You’re doing Gods work!
Date match on a 2 digit year added as failover(@spanishu) . Fixed issue with ExposedCasting not matching (@spanishu) Fixed Brazzers error handling when background banner was missing (@cooltwa)
Let me know if there is anymore issues. I will do what I can as time permits. I hope to add more sites soon but my professional life is keeping me pretty maxed out at the moment. Might be a week or so for site adds. Sites that have been donated for get priority however.
Once again, awesome stuff! Thanks!
Quick observation; Girlsway does not seem to be able to fetch posters for the scenes. Will this be fixed in the future? :slight_smile:
@Edeke Do you mean multiple posters? There is only one image file available on Girlsway’s site. If you mean you are not getting a poster after having to do a fix match…Either go into edit on the video and select the poster, or do an unmatch and then rematch the file. If neither of these work, remove the file from plex and add it in fresh. If you still are not getting a poster, send me the title and the log (Plex Media Server\Logs\PMS Plugin Logs\com.plexapp.agents.phoenixadult.log).
Sometimes Plex doesn’t like the priority of a poster image after a fix match.
Did all the things you said above. on multiple clips. Still not get a single poster. Only have the autogenerated-thumbnail, which is a frame from the clip. I couldn’t find a log (will look harder tomorrow). One example that doesn’t work for me is “Girlsway - Mommy and Auntie”. Finds all metadata but the poster.
I was able to grab everything with that title just fine on my system. I hope you can find the log. It should be in the same Plex Media Server root folder you added the plugin to. The log will just be in a different sub directory. Run a refresh metadata on the video prior to sending the log to ensure it’s in the log.
Just to back @Edeke up, I just tried Girlsway on a couple different files and while it does fetch metadata, it also doesn’t fetch any images for me. The same behavior.
As an additional feature suggestion to to the ones I made before. For Girlsway specifically (and some other sites, but that’s the one we’re talking about). There actually are more images, but they are stored under “Pictures” results instead of “Videos” (shoot name should be the same). I currently grab these manually for poster art, but as a new feature, it would be nice if that happened automatically.
Are you using the phoenixadult agent?
There are two agents by phoenix, phoenix data 18 which is for movies from data 18 and phoenix adult which scans the different sites.
Awesome, latest version fixed the older Brazzers scenes I was having issues with. Thanks!
first of all. Thanks for taking your time and creating this.
I have a problem searching some Tushy things, for example Take My Girlfriend For Your Birthday, but I can’t seem to find it. Anything I’m missing?
EDIT: NEVERMIND, wrong metadata agent (just read the comment above)
Feedback:
Some scenes have a huge amount of poster pictures but only 1 as background, but 99% of the pictures could be used as background too. What about just show them in background too? (saw that at Tushy)
Some requests, if you ever find the time to add them :slight_smile:
One bug that I now came across it, that oftentimes when I change the poster for a scene, it just shows an empty poster. Refreshing metadata brings me to have 2 posters in per scene, one that works, one that doesn’t.
I have a few more:
These seem to have the same website structure / search:
And
