Advice on Plex home setup
Hi guys,
I’m a newbie when it comes to Plex. And i’m kinda lost here at the moment.
I’ve done a bit of research, watched a ton of youtube vids, but i can’t figure out the basics of my new Plex setup. So i hope i’ve come to the right place;)
The goal
  • To play 4K movies (including raw gopro 4K clips) on my LG 55C7V tv. Just one directplay/stream at the time.
  • Have a Nas-like solution for the rest of my files.
The question
What is the best way to go?
1 get a NAS (+/- €350 not incl HDD) and a NVIDIA Shield TV (or similar).
2 get a NAS (+/- €350 not incl HDD) and a run Plex app on the LG.
3 get a mid range pc setup, with a CPU (Intel Core i3 8100 or similar) and a bit of RAM, a eco power supplie. Run Freenas and run the Plex app on the LG.
4 get a mid range pc setup, with a CPU (Intel Core i3 8100 or similar) and a bit of RAM, a eco power supplie. Run Freenas and get a NVIDIA Shield TV (or similar).
5 get big CPU (rizen 2700x or similar) and a bit of RAM. Run Freenas and the Plex app on the LG.
6 get big CPU (rizen 2700x or similar) and a bit of RAM. Run Freenas and get a NVIDIA Shield TV (or similar).
I don’t know if option 1 - 4 will run 4k vids or that i need the big bad CPU and/or the NVIDIA Shield (or similar). All the above are options for me. But if i can save money or the initial setup and power cost, why not.
Thanks, Bob
Thanks @trumpy81. So no need for a strong cpu as long as you can use direct play.
Than it matters what type of files i download, either or not the Shield can direct play them.
Do you find in ‘real life’ that most of the files can be played by the shield?
Oke i will. Thanks.
  1. Store your media files on Google Drive (Unlimited storage as part of G Suite for Business for $10/€8/£6.60 per month). Buy a cheap i3 ex-corporate PC from eBay ($100-200) for your server. As a client use MrMC on an Apple TV 4K or Nvidia Shield.
